Question about Nextbook Premium 8 Se Android
<!-- from fixya rte -->How can I get the internal speaker to work - Nextbook Premium 8 Se Android
    New Friend:
    Problem Solver:
  • 7 Answers
Try a soft reset; if that fails do a hard reset. The procedure for this is probably in the manual.
Posted on Nov 25, 2014
No sound except through headphones
The fact that the device produces audio output through the headphones indicates that the audio system is operable up to the headphone jack. Therefore, the fault must lie in the internal speaker, the wiring between the jack and the speaker, or the jack itself. Most likely, the internal speaker has gone belly-up and needs to be replaced...
Mar 26, 2016 | Tablets & eReaders
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
Orbo Jr. tablet. sound comes out of headphones but not without the headphones plugging in. I did a factory reset but no luck. Help
"No sound on external speaker" problem is often caused by:
- damaged speaker,
- damaged headphone jack,
- damaged audio codec (hardware).
You can try to ask your problem here: https://www.elvikom.pl
There are many service technicians with high-level experience, which may help you to repair your tablet.
Jan 19, 2015 | Tablets & eReaders
Why wont my tablet play out of the speaker only time I can hear anything is if I put my earphones in
Probably problem with the internal speaker.
Only thing you can try is, Just insert the earphones properly into the 3.5mm jack. Fit it correctly and pull it out at once.
Just check if that works or not. If still there is no luck, then probably the speakers are gone.
Jan 01, 2015 | Tablets & eReaders
How do I get my speaker to work I plugged in headphones and now the internal speaker will not work
Most times they do not work simultaneously by design. Try unplugging your head phones and the internal speakers should work.
Dec 03, 2014 | Nextbook Next3 tablet
No volume on my kindle fire hd
Try inset head phones or era buds. If they work, then the connection to the internal speakers may be a problem.
Apr 29, 2014 | Amazon Kindle Fire HD
Cannot hear radio broadcast audio
First thing to check is your settings for sound. Go into settings and click on sound . The options are there. Make sure it's not on mute or something similar. Try changing the setting. Next is plug in your earphones in the jack. If that works then your jack is open after you take the jack out. If none of this works then a connection to your internal speaker has come loose or off.
I am not familiar with your unit. Just standard stuff on all tablets is what I am suggesting.
Apr 14, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Internal speakers stoped working
MAke sure you did not download some type of app that controls volume also make sure the system as a whole is not muted if worst comes to worst backup your things and system restore hope i could help =]!
Mar 03, 2012 | Toshiba Thrive Android Tablet
Hi i have a gateway laptop, im having a hard time fixing the speakers,it started wen i tried to use my speakers for my ipod.when i took the cord of my ipod out of my laptop,the laptops speakers arent...
You have possibly broken the switch, inside the units Phono Jack, this is a common thing, there is a little switch, in the Jack, that cuts OFF the Internal speakers, when used. Sometimes the ball on the end of the Plug can force the contacts too far apart and they don't make contact and cut off the internal speakers. This is a difficult fix, as the whole laptop must be disassembled, the part unsoldered, and another good part re-installed. As a cheap workarround, get an inexpensive USB soundcard, and some small external speakers. Otherwise it's off to the repair shop, or get yourself a service manual and do it yourself.
May 18, 2010 | Tablets & eReaders
Volume on the computer varies with no manual assistance.
Unplug and plug your speakers. For a laptop like yours, you need to open it up to remove the motherboard for servicing.
In the meantime, remove your speakers and plug them back.
Apr 03, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Nextbook Premium 8 Se Android Logo
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
