Im trying to hook up my Samsung phone to my Sylvania flat screen with DVD player built in. .....and can't get it to work
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
What is the model number and O/S to your Samsung mobile phone? It it Android? If so, you have to download Samsung Kies software first to your system, and sync it with both TV and phone. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Procedure to download Samsung Kies Soft is given by one post in this site.
Posted on Nov 25, 2014
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
SOURCE: replace fuse for flat screen 37 sylvania flat screen
i have a black cloudy area about 2 inches wide and 14 inches long at an angle onmy 37 ninch sylvania hdtv
Posted on Oct 19, 2009
Randyincv
  • 17 Answers
SOURCE: i have a sylvania LD320SS8 32" digital/analog lcd tv witha built in dvd player
Take the Inverter Board out and check for Open windings on the 6 Transformers along the edge of the board. When you find one open, get the number off of the Transformer, Google it, buy one and replace the bad transformer. I was given one of these TV's and fixed it for $11. It's not rocket science, if you can use a DMM and a soldering Iron, you can fix this.
Posted on Nov 06, 2009
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
I have a portable sylvania dvd player-sdvd7038 asstpl model . i cleaned it with a dvd cleaner and now the voice on it is very deep and low. Also im looking for the manual to download. Thank you
DVD cleaners do not usually change the play back of the audio track on the optical disc. Are you using headphones or the built-in speakers?
The Sylvania SDVD7038 was manufactured by Curtis and the manual is available on the product page: http://www.curtisint.com/web/browser.asp?productID=SDVD7038&catName= . The direct link to the manual is http://www.curtisint.com/html/custservice/manuals/SYL_SDVD7038_ENFR.PDF .
I hope the link to the manual helps.
May 22, 2016 | Sylvania Televison & Video
Alienware x51 Desktop black screen on tv...
You have to enable HDMI on the TV and the Computer
Jan 30, 2014 | Sylvania Televison & Video
Samsung TV will only work as PC Monitor. AV/S-Video/Antenna doesnt work
is your antenna hooked up correctly and do you have all the cords hooked up and have you tried to make sure nothing has gone out on it
Nov 11, 2013 | Samsung Televison & Video
What do i need to do to make the dvd player appear on screen? help!!
read instruction manual, color out from player to set one at a time===pretty straightforward stuff. inputs on set are labeled so select that input and you should be set.
Sep 03, 2012 | Emerson LC320EMXF 32 in. LCD TV
I have a z50p3 I tried to hook a samsung 1600
Sorry, man I have the same problem, with the same tv and player. Did you ever get a solution? LG Service Tech came out and his LG bluray player worked, whereas my Samsung didn't hooked to the TV. (It would spordically work going thru my HK254 AVR.)
He said either 1) the Samsung player was defaulting to a format that the Zenith being 3 years old could not decode (eg. 1080P) or that I might need to change inputs several times to get it to sync up or 3) by an LG Bluray player.
He said the Zenith was old and that newer sets are built with circuitry to help navigate the handshake easier. He couldn't find any service bulletins on it, and the one I got from LG he said didn't exist.
Feb 28, 2010 | Zenith Z50P3 50 in. Plasma TV
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
I need a remote code for Sylvania NB500SL9 Blu-Ray player
try 093. it worked on my samsung remote for my insignia blu ray player. Insignia instructs you to use sylvania codes and this code is listed under DVDplayers in my samsung guide. like i said...it worked for me!
Dec 31, 2008 | Sylvania NB500SL9 Blu-Ray Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
