I have a Lenco KDV-309 flipscreen. problem is reception, I am using an outdoor aeriel which I previously used on another set in the same room. however I now have an problem with reception in that the
Tv aerial booster, no change. item is fixed location so cannot easily move to other site. this is the only tv aerial connection in the house.
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
Change the position of both the set and Ariel and try. If the room is at the ground floor of any building, signal strength will be very low, can cause unstable and grainy picture. Change the position of the Ariel and check. http://electronicshelponline.blogspot.com/
Posted on Nov 25, 2014
lukster
  • 217 Answers
SOURCE: Turns off by itself 10 minutes after use, and goes on and off
sounds like a main board problem
Posted on Apr 30, 2007
osborne382
  • 306 Answers
SOURCE: TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Posted on Nov 14, 2007
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
  • 45 Answers
SOURCE: Olevia LT26HVX turns on with blue screen then blanks out
seems like the main-board is having some issues.. the tv's main-board will have to be replace or repair..
Since the manuf. when out of buss.. the only way to get that fix is thru the 3rd party repair center called Amergence Technology in witch they service all Olevia Televisions..
There number is 866-965-3842 im sure they could give you an estimate on the repair cost for you.
Posted on Jul 29, 2009
Our reception becomes pixilated and unwatchable, we've retuned the tv and in another room retuned the set top box to no avail. Could this be caused by the antenna needing to be realigned?
try feeding a signal from a dvd or dvr to the tv if it looks well then , yes if you use an outdoor antenna id ck your wires and antenna , water seepage ruins many a wire feed in ,ill tell ya !!
Mar 02, 2017 | Televison & Video
How to hook up the antenna
If you are not using cable or Sat. TV, you need a DIGITAL outdoor antenna, preferably outdoors for better reception. Forget the garbage indoor window or set top systems as they will not pull in a good signal, unless you are near the TV Stations transmitters. Cosco or WalMart has TV Outdoor systems.
Apr 02, 2014 | RCA P46924 46" Rear Projection Television
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
May 24, 2013 | La Crosse Technology Ws-8418u-it Atomic...
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Jul 13, 2010 | Sony Audio Players & Recorders
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
Help! How to get the best TV reception in this part of my house!
the area where you live creates reflexions or gaps in the signal (seeing how hard is to get the signal) maybe mountains around maybe big constructions or just simple a deep in the overall terrain. In all this cases maybe the solution is to get signal from the sky. This is done by: ex (dishnetwork, comcast) or any of those vendors with the little round antenna that you pay monthly. Now if the problem is only in that room of the house; then an xtra instalation can feed signal to that area from the other areas in the house where the signal is working good with you other tvs around the house. Just a couple of splitters and good isolated cable is needed to transport it.
Apr 14, 2009 | Televison & Video
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Jan 16, 2009 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
