Question about Samsung Televison & Video
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect the dvd player from the tv the info button works but when i reconnect the dvd player it does not work. how do i get the info button to work again? Samsung led tv UA55C6900 connected to a Samsung BD-HDD combo
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Try resetting your TV back to factory mode. Press Mute, 1, 8, 2 then power on with remote.
Posted on Sep 03, 2015
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs. http://electronicshelponline.blogspot.com/
Inform them the problem you faces with the TV. They will surely provide a solution.
Posted on Nov 25, 2014
landsend
  • 1066 Answers
SOURCE: i bought a 32 inch flat screen tv dvd combo from walmart
the cable connection needs to be resoldered to the circuit board.
Posted on Mar 13, 2009
  • 380 Answers
SOURCE: My HDMI connection does not work with Blu Ray DVD
After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
Posted on Dec 30, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: have a Samsung led hdtv 46
The Blu-ray players need a firmware update, otherwise some new disc may not play.
Posted on Apr 28, 2010
  • 324 Answers
SOURCE: I just bought a Samsung
Make sure nothing is blocking the front of your DVD player. You need a clear line of sight between the lower right corner of the DVD player where the sensor is and your remote. If your DVD player is sitting high on a shelf or lower than you are when you are sitting in front of the TV, it may be at a bad angle to "see" the remote.
This will sound crazy, but it often works: While standing up, point your remote at the wall opposite your DVD player at about the same height, and see if it works! This is a sure sign that the angle between where you are using your remote and your DVD player needs to be adjusted.
FYI- this often works because bouncing the remote beam off of an opposite wall spreads it more than pointing toward it, and is a good way to test your remote.
Posted on Feb 24, 2011
  • 20 Answers
SOURCE: i am trying to connect
This might seem a little out there but you have hit the source button and scrolled down to the correct HDMI input for the device? Also if you dont see the correct input when you hit the source button then in the settings you might have that particular HDMI connection turned off.
Posted on Apr 15, 2011
I need to connect it to my flat screen TV how do I do it?
U need the appropriate adapter to convert your Samsung Outputs to the inputs of the tv.
Aug 21, 2015 | Samsung DVD-VR357
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
How do I connect my DVD player to my Apex flat screen TV?
Well, I don't know what kind of connections do you have, for my old DVD player I used an audio video cable. Connected audio video out from DVD to audio video in of TV. My current Blu-Ray player use the HDMI connection
May 11, 2015 | Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Samsung cs21m40mj no picture
I don't know if this helps, but I had the same problem in reverse. Great picture - no audio. I finally unplugged the TV and all devices connected to it (DVD player, cable box, etc.) waited 3 minutes and plug everything in. The audio was restored.
May 19, 2012 | Televison & Video
How do I connect my dvd player to my tv ?
There's many ways to connect your dvd player with your flat TV. You can use hdmi cable or component video connector. It is better if you tell me the exact unit model of your Samsung flat tv and dvd player so that i can give you the exact connector you can use. Hope its help. Have a good day ahead.
Sep 05, 2011 | Samsung Televison & Video
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Blank screen saying (mode not supported )
I had this today on my Samsung 46" TV while connected to a DVD Receiver (Panasonic).
I don't know why it happened in the first place but the DVD was trying to output a format that the TV could not produce.
Holding the Cancel button on the Panasonic Remote for a few seconds fixed this.
Dec 03, 2008 | Televison & Video
Televison & Video Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
