Question about LG 55 55LW5600 3D LCD TV
LIGHTNING STRUCK MY ANTENNA AND SHORTED MY TV IT COMES ON BUT NO PICTURE OR LIGHT OR SOUND.
LIGHTNING STRUCK ANTENNA NOT POWER BECAUSE SURGE PROTECTOR AND OTHER DEVICES ARE FINE THE POWER LIGHT COMES ON BUT NOTHING WORKS
    Sergeant:
  • 291 Answers
I once had lightning enter a screen window, hit the TV and blow the control knobs off of it before jumping into the kitchen and pealing the counter's top. That dates me as TV's do not have knobs now. Woefully, what it would cost you in labor to have the internals of the TV checked and then replaced (and the delay while you wait) will make you purchase another set. There is just no way to predict how much if not all the circuitry was fried. When the lighting entered the antenna, it ran wild in the TV's circuitry and those are very tiny and vulnerable tracings that got "stomped" upon. I think you will find that the only thing that will work IS the power light. Why does it work and not the TV? Because the lightnings current did not run through the power line and thus blow the power indicator light! It came only through the antenna and fried the circuitry there before it ever reached the power indicator light. I presume this was not a surge protector that had a connection for the antenna. Even it had such, it is unpredictable whether it would protect the TV. Your TV is toast.
Posted on Nov 25, 2014
  • 192 Answers
SOURCE: blinking power light
This set has a power supply and signal PCB. Since the indicator light is blinking, I would consider the problem to be a missing voltage from the power supply. Unplugging the set for a couple minutes may solve the problem. If not the set may still be under warranty. Contact LG (800) 243-0000 for a servicer in your area. Hope this helps.
Posted on Apr 29, 2007
dsacco86
  • 1077 Answers
SOURCE: My lg tv wont turn on.
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Posted on Sep 09, 2009
ginko
  • 19396 Answers
SOURCE: Power went off and then tv will not start
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Sep 10, 2009
Testimonial: "Thanks. You seem to have covered the problem which I will try before getting some technical help."
joeguest2
  • 2080 Answers
SOURCE: All of a sudden the
Normally this is indicative of a faulty power supply circuit inside your TV.
The easiest way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one.
You can find a replacement circuit board on Ebay by searching for your TV's model number.
Here is a link to one currently available for about $129 plus shipping:
http://cgi.ebay.com/LG-EAY32731102-6709900017C-SMPS-Power-Supply-Board-/170641303008?pt=LH_DefaultDomain_210&hash=item27bb03a5e0
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
Posted on Jun 20, 2011
gopakumarg43
  • 75304 Answers
SOURCE: have a 42lg50ug.auslhr recently had a power surge in home tv has no sound or picture tried to connecting to different outlet in another room but it still wont show a picture or hear a sound
Hrllo
The power supply board of your TV is faulty. It canbe either the fault of a protection fuse, of switching regulator components. We can't predict, which will be faulty, becuse, the set has damaged during a power surge. If you have knoledge in electronics, and some experience in service electronic equipments, you can do it yoursef at home. Some power supply board faults are repairable, by replacing the defective components on it. But, to detect the defective component you must have its schemaic diagram [Service Manual] with you. Witheout it, you can't get what exactly had happend to the board. I've the service manual for your set, but I can't, send it to you without prior permission from Fixya. Toe get it, you have to get me over Fixya, by purchasing onw amoung my LD services advertised there. Unlike previous Fixya Site, the new one is different, and you can choose the experts you want to. The picutre of the power supply toy your Tv is attached here.
Posted on Nov 13, 2011
I have a Vizio model E601I-A3, lightning struck outside my house and fried some of my electronics, despite everything being plugged into a surge protector, anyway it's getting power but I have no picture...
Replace the TV as it has been damaged by a power surge and the faults will be recurring.
A home surge protector will do nothing to break the power of lightning.
Oct 26, 2017 | Vizio Televison & Video
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Hello, I have a L.G. 55LW5300 3D Hello, Hello, I have a L.G. 55LW5300 3D LCD T.V. and it will not turn on?
You need to contact your insurance because that surge destroyed the TV circuit boards.
Sep 28, 2016 | Televison & Video
What to test with voltage meter for non working Sony TV.
There may be an internal fuse that has burned out, but opening the cabinet on a TV of any sort is a dangerous thing to do if you're not sure what you're doing!! This needs to go to a repair shop -- or the dump. (It's probably cheaper to buy a new one than to have it repaired.)
Aug 27, 2016 | Sony Televison & Video
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Tv tries to come on and the Vizio Logo lights but is very dim. It will go from amber to white, go off and repeat. I pressed and held the on button on the side and it began clicking and came on for about 45...
Lightning definitely sounds like the issue.We had our computer plugged into a surge protector last year but our computer got fried.We purchased a Belkin surge protector which is much better.The smallest one they sell I believe is 6 outlets for $50 BUT they back that with a $50,000 guarantee.If something fails due to their product,they will reimburse you for up to $50K,and I already called just in case,you do not need receipts.They make up to 12 outlets and that has a $300K guarantee.We live in the lightning capital of the country,Tampa area,and so far no problems.Also,it's not really good to hold down the button to force it to come on because the clicking probably means it's trying to save itself,but at this point it doesn't much matter.The TV will need to be looked at.I wish I could help more but the TV makers won't let me as a consumer,find any parts prices or diagrams.Sorry , but good luck!
Aug 05, 2010 | Vizio VF550M 55 in. LCD HDTV
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Tv struck by lightning
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Jul 10, 2009 | Panasonic PT-51HX41 51" Rear Projection...
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
LG 55 55LW5600 3D LCD TV Logo
63 people viewed this question
Computer Repairing
Computer Repairing
