My samsung 67 in flat screen has a double picture and I have no idea why. An example would be: it it says weak signal the display shows it like so "weak signal" " weak signal" The pic is doubled. Please help. I paid a bundle for this tv
    Sergeant:
  • 291 Answers
Http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB8QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dj7vl7-vZEL8&ei=1Dl0VKbHCobEmwWHyYL4DQ&usg=AFQjCNEAyKFYUTGQJSdIJHNNQNODhqatWQ&bvm=bv.80185997,d.dGY
That YouTube link may help as it deals with the double image problem on a Samsung LED TV. It should at least give you a clue about the nature of the problem. You might have to try Samsung's tech support otherwise. I don't think this is a matter of needing some 3rd party signal amplifier because I figure you are using cable TV if you paid a bundle for a set.
Posted on Nov 25, 2014
  • 38 Answers
Is it a 3D tv? You may have 3d switched on
I have a SAMSUNG 58" 1080p Plasma HDTV FP-T5884. I can still switch the TV on but the screen shows pink bars no mater which source is selected. This video from a guy on youtube shows exactly the same on...
That is a typical case of poor/weak signal getting to the display via the FFC, either is a poor (or NO) contact problem, or a defective FFC.Look for the Flat Film Cable looking similar to the one in the picture, and make sure no pinching/broken traces. And/or confirm the conection at each side. Good Luck!
Mar 30, 2015 | Samsung Televison & Video
Vertical bars on screen for certain colors
Sounds like a panel fault. Contact the authorized service centre for Samsung, to confirm. Gopakumar Gopalan Google
Mar 21, 2014 | Samsung 46 LN46D550 LCD TV
My 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.
It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
Dec 12, 2012 | Samsung HL-67A510 67" DLP HDTV
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Signal Problems
firmware needs to be upgraded call samsung and they will sent it to you
Apr 27, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
The picture seems very coarse and has diamonds running across it
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Weak signal showing on my l e d samsung haven't used it yet (new)
Try to double check the power cable is well connected if so you have to know that some screens come from the factory with some problem and in this case you have the right to replace it from the seller.
Dec 16, 2008 | Samsung LN-T4665F 46 in. LCD Television
No signals. screen is blank. power green light is blinking.
Its not a malfunction. blinking light is indicator shows that no appropriate input signal detected. If you are using laptop refer your user manual to toggle to external display device. For example in most of the Toshiba Laptops requires to use Fn+F5 in order to use external display device like you have. If issue still persist you may post again by including the details of your laptop/desktop model.
Good Luck, Happy New Year
Nov 09, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Display problem of samsung syncmaster 450B & 550s
BAD NEWS THE PICTURE TUBE IS WEAK THE ONLY FIX IS TO REPLACE YOUR MONITOR WITH A NEW ONE
Apr 28, 2007 | Samsung SyncMaster 550S Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
