When I turn on my unit the cooling light flashes but nothing happens
    Problem Solver:
  • 16 Answers
Your unit may have a wall control which can set the Evap cooler to a pre fill mode time which fills the base with water then there is a pre wet mode which starts the pump to wet the pads. After both these functions have completed the fan will start. This could take up to 4 minutes before the fan starts and can be programmed out if not required.
Posted on Nov 26, 2014
On my honeywell thermostat cool on keeps on flashing but ac dosent come on
On a Honeywell thermostat the flashing means that the system is in a delay to turn on the compressor. This is used to protect the compressor from coming on and off too often. The normal delay is about 5 minutes. After that the system should come on. If not there is s problem.
In order to help us help you we will need a little more information. What happens either at the inside unit or at the outside unit after the thermostat stops flashing "Cool"? Any fans come on? Do you hear a "KLUNK"? Any sparks? Please let us know so we can help.
Nov 20, 2011 | Honeywell Heating & Cooling
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
We have not used our Daiken wall mounted inverters since the cold days of winter, and now the remote control will turn on the lights, but nothing else goes on and no cool or warm air will come out. The...
Normally, there will be error code whenever the problem arises. But if you couldn't see the error code, depends on counting number of flash, we can diagonize. Any how, with your limited statement, I hereby try to solve your problem.
Indoor Room thermistor error 1time Flashing
Indoor in-piping sensor error 2times flashing
Communication error between in and out 5times Flashing
Indoor Out-Piping sensor error 6times Flashing.
Hope, this helps you.Thanks.
Dec 25, 2010 | Fujitsu Heating & Cooling
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
Our projector doesn't turn on anymore. Nothing happens when I press the power button, not even the beginnings of the start up process.
I just had the same problem today. All lights flashing and won't start up. Noticed the flashing the other day, but they stopped after i turned it on. Now nothing
Jan 09, 2010 | Optoma Office Equipment & Supplies
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
Jan 03, 2009 | Microsoft Xbox 360 Console
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
