Question about Sony HDR-PJ240E/B Full HD Handycam Camcorder Black, PAL
How to project an image from an external device from a Sony Camcorder HDR-PJ240E?
I have connected my Sony Camcorder HDR-PJ240E with the HDMI cable provided into the Projector input of the camcorder and to the DVD player HDMI output
    Problem Solver:
  • 10 Answers
Simple solution. You connected an output to an output. The Camcorder 'outputs' image from it so you need to plug it into an input on your TV. You will then see image from the camcorder on your tv.
Posted on Nov 25, 2014
Testimonial: "I connected the HDMI output from the DVD player to the Projector in (Micro HDMI)of the Cam Corder"
  • 2 more comments
  • vitorvious chops Nov 25, 2014
    SORRY I misread. Give me a minute.
    http://pdf.crse.com/manuals/4531548111.p...
    There is a link to the manual in case you don't have it. I skimmed it briefly my pressing ctrl+F and then typing 'projector' into the find box. Use that to do some further investigation yourself. However from what I gather I believe you cannot use the HDMI cable from the dvd player because it will only import the DVD in Standard format so you need a Standard definition cable.
    Do you have the converter and all hooked up? Maybe I'm just misunderstanding your situation if everything is hooked up correctly then you press the bottom left button on the screen and then use the multi selector (I think it scrolls left and right) on the screen to find the correct selection to project from the DVD.
Why when I use the inbuilt projector of the Sony Camcorder HDR-PJ240E with an external device,the projected screen becomes plain blue after a few minutes?
This maybe due to the external device not receiving signal to keep the display on the screen or a cable that isn't quite right. Many HD cables can cause this issue due to a security feature built into it to prevent streaming copies which helps prevent piracy. If you are using say an HDMI cable, try a different one.
Nov 26, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
It is brand new and the store has exchanged it for another Camcorder and it is still the same problem
I Will continue adding my two cents to all of these posts :)
Another thing to try I haven't mentioned would be to play a movie that you know is PAL. Since the camera is PAL.
Color info and reference freq. is different. In fact unless you remove region codes all together use a converter box there is no way to play a movie that is NTSC. It wouldn't even read out on your LCD screen in the spot where it is suppose to be.
Nov 25, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
How to project external device through the SONY HDR-PJ240
  • -Open LCD screen
  • -Press the 'View images' button to enter playback mode which looks like > with a square around it
  • - Then use < and > on screen to SELECT the DVD
  • -On this same screen TOP Right Hand corner of the screen you see the format mode. Select the SAME format as the file your trying to play.
Will a sony HDR-SR10E camcorder support a firewire IEEE 1394 cable
hi,
No, sorry but this cam doesn't have FW port...
if it is for access to your records for editing, use USB
If it is for streaming, broadcasting or recording on a PC, use the HDMI output and HDMI capture card...
that's all...
cheers,
mich
Nov 02, 2012 | Sony HDR-SR10E HDD Camcorder
Please help me ... how can i transfer videos from my Sony HDR-FX1000E Camcorder tape to save it into my laptop (SonyVPCEB1M1E)? i will be waiting to hear from you... thanks a lot.
Transferring video from your FX1000E should be quite simple using an HDMI cable. If you've recorded in HD, the files may be quite large, so make sure there's enough space on your HD to accommodate them or the transfer will error out (which might be the problem you're experiencing). Once transferred, the most recent version of Windows Media Player should be able to play them. You may want to convert them to MP4 files to save some space too. If space is an issue, think about getting a 1TB external hard drive to transfer them to. You can then plug both the FX1000E into your laptop and the external drive into your laptop at the same time and when capturing the footage save it directly to the external drive.
Dec 28, 2010 | Sony HDR-FX1000 Mini DV Camcorder
Hdmi connection for camcorder to hdtv does not work.
If i am to understand you correctly, you are are connecting a mini-HDMI adapter to the TV, and another adapter to the camera, then connecting the two adapters together.. i believe this may be an issue..
Too many adapters can actually cause signal issues, especially when converting a digital signal to analog, then back to digital, or vice versa.
Check to see if the manufacturer of your camera has an adapter to go directly from the camera output source to your TV's input.
Cam > adapter > TV = Correct
Cam > adapter > adapter2 > TV = Signal degridation
May 28, 2009 | Acer Aspire m5640 PC Desktop
What is the docking station for?
a usb cable will work... the docking stations are handy as you just put the camera/camcorder into the docking station ... no extra cord... often has the charger built in as well
Robert
Jan 19, 2009 | Sony HDR-SR11 Flash Media Camcorder
Sony HDR-PJ240E/B Full HD Handycam Camcorder Black, PAL Logo
94 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
