Question about Radio Communications
I have a cobra 29 camo and i can pick up weather perfectly but if i go to the cb channels and lower the sq i cant hear static i actually pick up a faint weather channel please help
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Off frequency in pll section.take it to a tech and let them set it back to specs for you.
Posted on Nov 25, 2014
5 Suggested Answers
  • 23 Answers
SOURCE: an old cobra 29 23 channel Cb that has no audio or key up
This is a typical indication of the finals being blown. Probably have to take it to a shop, but it would be expensive compared to the value of the radio
Posted on Nov 04, 2009
  • 1274 Answers
SOURCE: can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
Posted on May 17, 2010
benjwgarner
  • 5 Answers
SOURCE: Just hooked up my cobra cb radio with attena and
CB channel 19 is one of the most frequently used; it is unofficially designated as a "highway information" channel. It is not always hot, however. It is possible you may have your squelch control set too high. If you cannot even hear static, this may be the case. If you can, the channel may just be empty. Try scanning up and down the band until you find something.
Posted on Jul 07, 2010
  • 773 Answers
SOURCE: With my cobra 29 wx nw st I can not pick up any
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Posted on Aug 09, 2011
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
I have a cobra 29 with echo, tweeked and tune. I can transmit strong and I hear those who speak to me but I dont have any static like you do with a new radio. Is this something I need to worry about as Im...
Make sure the squelch is turned all the way to the left, the RF GAIN is turned all the way to the right. The cobra 29 has a very good noise blanker, Turn the ANL/NB switch to off, You will probably hear a Lot of static, As long as you have a good ground on the radio and antenna, and your SWR is 1.5 or lower, you need not worry about static.
Oct 05, 2012 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd but have trouble maintaining any clear channels. Is there a way to maximize station clarity?
I just saw your message and the problems you have been having, from your description you have managed to get everything sorted out and working. I to have been into cb's for many years and enjoy the challenge tinkering with the system and I congradulate you on a job well done.
Feb 28, 2012 | Cobra 29 LTD CB Radio
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Can not get static out of radio i have a cobra 29 with weather channel the squ knob seem 2 b not working sometimes can u help me
Turn the squelch down, and the RF gain all the way up.
You need to realize that some times, there is not a lot of noise out there. Right now lately there has been due to skip. But it does die down. When you hear a lot of noise for a while, then it goes away, it messes with your head. You don't hear anything, but that's because its quite out. I would test it by talking to some one on the radio. If you can hear them just fine even though you don't hear a lot of static, then its just quiet out.
Jul 23, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have my NEW cb wired correctly as the mannal says and my antenna is a NEW 48 inch fiberglass antenna mounted on the highest point on my truck and the cb has been tuned in just as the mannal instructed.....
Hello ilatapy,
Welcome to FixYa.
My name is John, and I will be helping you with your issue.
Make sure that your antenna is grounded good to the body of the vehicle.
Check the connection in the back where the antenna plugs in.
Put your channel selector on channel 19 and make sure the Weather button
is not pressed in. Turn the RF GAIN to MAX, MIC GAIN to MAX .
If you still have issues, let me know! We are here to help you!
Comments and Testimony,s are always welcome here.
Thanks for choosing FixYa today and in the future.
John
Feb 18, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Bad static
The Cobra 20 NW ST Wx is ( in my opion ) a very poor receiving radio. The ST is a bummer in all Cobra radios. The Static is apparent for the atmospheric conditioons and definally power lines and any high voltage will be picked up. When I get a customer with similiar complaints ( and there are a bunch ) I normally recommend that we turn the receive senativity down a bit. Sorry for this advise.
Ed
NC Electronic
Mills, Wyoming
Nov 20, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
