F3E2 Error code, installed new water temp sensor , still same code
    Problem Solver:
  • 19 Answers
Model? Brand? What else does it do?
Posted on Nov 26, 2014
I have Duet waSher, model #WFW9151YW00. I have an error code F3E2. Thought it was the temperature sensor, which we just replaced, but still getting the same error code. Now what?
This could be a wiring fault between the water temperature sensor and the control unit. Make sure that the connectors are properly seated at both sides. Sometimes, one section of the wiring can get pinched and one of the wires in that harness could break. Check that all of the wires in the harness have continuity; the wiring may need to be replaced. Clean out the trap before the discharge pump just in case the error is from a different part of the washer's system.
I hope this helps.
Dec 01, 2016 | Washing Machines
Code F3E2(temp sensor) I replaced it and checked for continuity btw sensor and CCU,all good. still throwing code and wont work. what next?
Check for voltage and ground at the sensor plug. Check the sensor for resistance, Could have bought a bad one. After that your probably looking at replacing the ccu. I would get it on a scanner first.
Feb 24, 2016 | Cars & Trucks
I was receiving an F3E2 Error code which states something to do with the water temperature sensor. I got a new water temperature sensor and replaced. Now the washer will run fine without any clothes in the...
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23°F to 217°F
[-5°C to 103°C]) during the water-heating step of the WASH cycle.
Possible Causes/Procedure
- Unplug washer or disconnect power.
- Make sure that connections to water heater & CCU (TH2 & HE2 cavities)
connectors are not broken or with wires detached, and that connector internal
pins are visible.
- Check continuity from the water heater sensor (black wires) to CCU
(TH2 cavity) connector.
- If the continuity diagnosis failed, the Main Harness must be replaced.
- Check the resistance of heating element.
- Check the resistance of the water sensor.
- Plug in washer or reconnect power.
- Verify the washer operation by running the Diagnostic Test cycle.
- After the diagnostic test has finished, unplug washer or disconnect
power and wait for 15 seconds.
Water Temperature Sensor
1. Unplug washer or disconnect power.
2. Disconnect the wire harness from the water temperature
sensor and measure the resistance of the sensor. Use the
following table. An abnormal condition is an open circuit =
infinity; Water Temperature Sensor must be replaced.
Temperature Results
32°F (0°C) 35.9k ?
86°F (30°C) 9.7k ?
104°F (40°C) 6.6k ?
122°F (50°C) 4.6k ?
140°F (60°C) 3.2k ?
158°F (71°C) 2.3k ?
203°F (96°C) 1k ?
Nov 25, 2014 | Washing Machines
When i used my washer after 3-4 mins f3 e2 maytag front load washer , changed ntc but still same
I am sorry to hear that you have error code F3E2. I know how upsetting error codes can be. I see here that for your Maytag washer, error F3E2 means there is a water temperature sensor error. Below is to test the error
WATER TEMPERATURE SENSOR ERROR:
1. If the water temperature sensor valve is out of range (23 degrees to 217 degrees F or -5 to 103 degree C) during the water-heating step of the WASH cycle.
Possible causes/procedures
a. Unplug washer or disconnect power
b. Make sure that connections to water heater and CCU (TH2 & HE2 cavities) connectors are not broken or with wires detached, and that connector internal pins are visible.
c. Check continuity from the water heater sensor (black wires to CCU (TH2 cavity) Connector.
d. If the continuity diagnosis failed, the Main Harness must be replaced.
e. Check the resistance of the heating element.
f. Check the resistance of the water sensor.
g. Plug in the washer or reconnect power.
h. Verify the washer operation by running the Diagnostic test.
i. After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
Below is the diagnostic test. I have it in two halves so you can read it best that way.
If you will submit your model number I will be able to help you further.
Nov 25, 2014 | Maytag Washing Machines
Had an error code F3E2 show up on the screen
F3-E2 Oven over heat. Replace Sensor
0ae81cf.jpgOven sensor should measure around 1100 ohms.
Oven sensors should not be grounded. Continuity from frame to either sensor wire is a bad sensor.
Got popcorn? Heres a movie:
Oct 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
