Question about World Marketing Kozy World KWP196 3-Plaque Liquid Propane Gas Vent-Free Heater
After installing my kozy world heater and lit the pilot the heater came on. all three plaques. this happened while the knob was still in the pilot position. the heater wont shut off.
Lit the pilot and the heater plaques lit too in the pilot position. Will not shut off without turning control knob to off position.
    Sergeant:
    Champion:
  • 282 Answers
I actually have three of these and what I found was the gas valve was stuck in the open position you may need to replace it or possibly remove it and try to clean it of any residue but be very careful if you don't know exactly what your doing then you need to get a pro. Remember that your dealing with propane and it could ignite and cause serious damage to you and your home. Please be very careful and you might want to call the manufacturer and talk to them about it. Because it is a gas appliance they have a responsibility to you if anything should happen then they may be liable.
Posted on Nov 26, 2014
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
Pilot goes out when I try to turn the knob up
If the pilot stays on when you are holding it down (you are manually opening the gas valve) but won't stay lit when you let the knob go, then the thermocouple is bad. The pilot knob needs to be held down for 30 secs or so. The pilot flame has to heat the tip of the thermocouple long enough to for it to output a small electric signal (that holds the gas valve open). If you look at the pilot flame, you will see the tip of the thermocouple in the flame. That copper tube runs from the flame to the gas valve and is easy enough to replace. They sell them at most hardware stores. If you see a lot of ash buildup on the tip, you can turn the pilot off and clean the tip and try again.
Dec 26, 2013 | The Companion Group Kozy World Portable...
Every time my kozey world heater kicks own and burns for a period of time then kicks off my pilot light kicks off to
check pilot generator.....what is the current being produced?..........maybe you are getting a negative down draft that happens to blow pilot out........start with thermal couple
Dec 05, 2013 | The Companion Group Kozy World Portable...
5 brick wall mount lp gas heater smells like exhaust
Better get a professional to look at it. you could kill yourself or some one else if you do it yourself. If I gave you an answer what I thought and some one died because of poison gas then I could be held responsible as well as you.
Mar 28, 2017 | World Marketing Kozy-World 5 Plaque...
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
My Kozy heater turns off after a few minutes, I then have to re light it and when it kicks on again after a few mins it turns off again. It will stay lite if I turn it down but when it goes on agin it will...
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.
1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)
2. Make sure that the tip of the thermocouple is in the pilot light flame.
3. Make sure that the thermocouple is clean.
Mar 22, 2011 | The Companion Group Kozy World Portable...
I just bought a brand new Kozy World blue flame heater and the pilot light will not stay lit and when it is lit, it goes out as soon as I turn up the nob.
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Nov 25, 2010 | The Companion Group Kozy World Portable...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Oct 26, 2009 | The Companion Group Kozy World Portable...
World Marketing Kozy World KWP196 3-Plaque Liquid Propane Gas Vent-Free Heater Logo
134 people viewed this question
Top World Marketing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a World Marketing Heating and Cooling Expert? Answer questions, earn points and help others
