Question about Vizio Televison & Video
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Posted on Nov 25, 2014
3 Suggested Answers
toddthetvmd
  • 101 Answers
SOURCE: i have picture but no sound on my 42 inch vizio
If you received a remanufactured board it might be defective,Or did you forget to hook back up the speakers? Sounds dumb but happens alot. Speaker wires get in the way,we disconnect them to look at a board or replace one.Often gets over looked.But I have received several defective boards.Hope this helps. Toddthetvmd
Posted on Oct 26, 2009
  • 451 Answers
SOURCE: No imaging, have sound, backlight, etc.
It may be an input cable problem. Check hdmi and or coax cables to make sure they are not damaged . If you have another tv hook cables up to it to make sure they are working. Hope this helps.
Posted on Dec 31, 2013
Vizio TV Model M550SV. My tv has picture but no sound. I have reset cable box and changed to different input. Also the Netflix app on tv has no sound either. DVD player also has no sound thru the tv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Dec 28, 2016 | Vizio Televison & Video
Apologies!! By trying to delete duplicate message, both were deleted. 5yr old 55" Vizio LED loses sound after 10-20 min. Both speakers & AV jacks. Both cable and dvd.
check and replace the damaged component/s at its audio output section circuit. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Dec 08, 2016 | Vizio Televison & Video
Sound but no picture. Vizio E470i-AO
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.....
Jul 18, 2016 | Vizio Televison & Video
Repairing a Vizio TV
Jul 12, 2016 | Vizio Televison & Video
My Vizio Smart TV has no sound
Sounds like you may need to replace the audio circuit board. If you are comfortable with taking apart your tv, you can find a dealer on this site who provides new and refurbished circuit boards for televisions. It is a shame that your tv is so new and causing you issues. Good luck and have a great day!
Aug 30, 2015 | Vizio M550SV 55 Inch Class Edge Lit Razor...
Vizio M550SV no picture. Back lights and audio good. Where is the tcon board on this unit?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 30, 2015 | Vizio M550SV 55 inch Class Edge Lit Razor...
Dec 31, 2013 | Vizio M550SV 55 in. HDTV
1.5 year old Vizio 55" M550SV now has color vertical lines edge to edge. Audio ok. Image here: http://jaxehost.com/vizio/m550sv.jpg Likely cause. Happened after first cold night. Worked ok first 10 mins,...
it looks like the panel is going bad or the main board. try to change the main board if that does not fix your problem the panel is bad. open the tv and get the main board part number and look for it on ebay.
Oct 24, 2013 | Vizio 55" M550SV 1080p 240Hz Widescreen...
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
Televison & Video Logo
276 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
