Paper Schrader doesn't work - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 282 Answers
Could be a lot of problems. It could be the sensor switch when you insert paper. Could be a bad fuse which by the way is internal to the motor and can't be replaced. Shredders usually have a setting for reversing so you might want to try that. If it does work then you can tule out the fuse and motor. Sometimes it is better to simply but a new shredded they are cheap enough.
Posted on Nov 26, 2014
How do I press a schrader valve to release pressure on a 1996 ford crown victoria?
Fuel Pressure?
Just push the valve stem down carefully with your
finger nail or small round tool
& have paper towels to catch the fuel
Engine has to be cold to work safely
Jul 01, 2013 | Cars & Trucks
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
My innertube leaks air and i am no familiar with the air intake device on it
There are two kinds of valve on bicycle tubes, Presta and Schrader. You are probably more familiar with Schrader because this is the type used on cars and most bikes. And I am guessing that you have Presta on this bike (Presta is skinnier than Schrader, and it has a little nut that you unscrew, where Schrader has a spring inside it. Google images for "Presta Schrader" and you will see both kinds, and you will also see a little screw-on adaptor that you can use on a Presta to make it fit your pump or air-hose like a Schrader. You can buy these adapters on-line or at any bike store. Good luck!
Oct 03, 2012 | Fuji Bicycles Cross Comp
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
I have a problem with my HP Photosmart Pro B8850, when I try to printout an A3+ photo image, the printer doesn't recognize the A3+ paper size and provides a diagnostic of uncompatible paper size. The...
Many printers can detect where the movable partitions in a paper tray are. If they get moved from the "Letter" size mark, the printer will detect that and act accordingly. Make sure if your printer has the movable partition it/they are in the correct position.
You can download the user manual for HP Photosmart Pro B8850 from here http://www.bhphotovideo.com/c/product/540937-REG/HP_Hewlett_Packard_Q7161A_Photosmart_Pro_B8850_Inkjet.html
Hope this helps.
Please rate if this solution was helpful, thanks!
Jul 18, 2011 | Computers & Internet
Which side do I use for a presta valve? How do I close it; yellow lever at a right angle or parallel?
The Side for a presta valve doesn't have what appears to be a pin inside. The schrader side has the pin. Just try putting it on a valve and pumping. If there isn't an air tight fit it means you need to move the leaver to the other position.
Jul 14, 2011 | Topeak Joe Blow Sport Pump
Can't get this pump to work on either schrader or presta valves! Help!
Its probably the fact that there are two separate holes for presta anad schrader, if so put your finger over the one you want to use and give small pump to vent it then attach, if not then you have to screw off the cover and invert the inner rubber core for presta or schrader, can you give me more details or pic...
Mar 26, 2010 | Cycling
jasbo
jasbo
