How possible is it for me to fix a receiver in which the volume is either not on(no sound at all) or on full(pasted against the wall clawing your face off and bleeding from the ears). The receiver has
There's no incremental volume stages, it's either totally full blast volume, or not on at all - the volume is turned right off, with the receiver still powered on.....
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Sounds like a faulty volume encoder , just replace the part and it should fix the problem
Posted on Nov 26, 2014
  • 2427 Answers
SOURCE: receiver shuts off at times
Those recivers are usually preety good oones with little to no problems. Its just when it gets a certin age it extends its life. You can take it in to a technician to have it serviced, mostly you have cracked solders on the board which will accout for the problems you are having. there might be a few things that need changing but basically your recuver is good it just needs servicing thats all.
Or if you prefer you could get a new one.. BUT YOU CAN JUST HAVE THE CURRENT ONE YOU GOT SERVICED..
a service wil include
re-soldering cracked or loose solders on the board
changing a couple of stuff, maybe capicators or resistors and unlikely an ic.
dusting it
So just take it in to a technician for a service cause its reached it life span ,,
Posted on Jan 05, 2008
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Posted on Aug 17, 2007
  • 4234 Answers
SOURCE: Technics SA-DX950 surround sound problems
The most likely culprit here is the output protection relay. The contacts are a little corroded and the higher volume "jumps the gap" temporarily "cleaning" the contacts. The relay should be changed. I don't have the manual with me, but the following relays are in the unit. One of them is the speaker relay:
Part # Cost
RSY0054-C $12.63
RSY0040M-0 $ 5.89
K6B2AHA00014 $ 8.14
Dan
Posted on Nov 12, 2008
SOURCE: hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Posted on Mar 08, 2009
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
Audio seems weak...how to increase volume
this is gotta be the largest complaint I hear from folks when they get a new flat screen , its not loud enough or the sound sounds muffled
flat screens are flat ! so theres no good way for mfg to put the speakers facing forward so sound has to hit the wall behind it first then gets directed forward to you ! (low/muffled)
sound bars help with this , but for true rich sound , id go with a video receiver amp combo , some of these even have built in dvd players , and arrange its speakers in a forward facing direction
Sep 16, 2015 | Samsung UN46C6300 TV
I have a 22 year old Luxman receiver. The left speakers periodically turn off, but seem to recover if I really turn up the receiver volume. I did just reconnect the speaker wires in an attempt to fix the...
To be honest it sounds as though your volume control needs a clean, try to find some switch cleaner (servisol or similar) remove the casing and spray into the volume control from behind the face plate as apposed to from the front. Rotate the volume all the way back and forth several times to clean the tracks, I have used deodorant in the past to achieve the same result but as this will leave a residue, probably not recommended as a permanent fix. Obviously do these actions with the amp switched off, otherwise you will at the very least annoy your neighbours with the loud volume.
Hope this is helpful.
May 06, 2011 | Audio Players & Recorders
I have a pioneer vsx 5000 receiver everything comes on but no sound comes out is it easy to fix
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Mar 18, 2011 | Audio Players & Recorders
I have a marantz sr4320 receiver. The volume control knob is not working---I can't get any sound no matter the volume number. "d8" is now showing, too, following the number. I have followed...
Do you mean "db"?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Turn the volume down.
While you're squinting at the front panel, find the manual and evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Mar 09, 2011 | Marantz SR-4320 Receiver
Iw-803 earthquake sound in wall speaker throws amp into protection mode at high volume.. removed all speaker components ( woofer, mid, tweet) and just hooked up crossover - still shots at high volume....
many amplifiers protect against a short and against an open. They are looking for speaker resistance within limits. Your wire to the speaker may be too long or too thin. You may have hooked up more than 1 speaker per output causing too low resistance. Keep your wires short as possible and use 12 or larger gauge wire if you are driving large wattage speakers. Check the ohm rating on your speakers and compare them with what the amplifier calls for. Hope this helps
Jan 03, 2011 | Earthquake Sound IW-803 Main / Stereo...
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Cant get sound
Hello....No Sound, No Volume Control, Mixer not Found…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE..VERY..IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots....
all the best...
Dec 21, 2009 | HP f2105 21" LCD Monitor
Pioneer deh p80mp
parts.com but you can fix it with jbweld. just remove the plastic with metal piece that is stuck to the volume button ON the faceplate and place it back in the center of the volume button knob. mix both pastes together and apply it aroun the plastic center of the knob. Ps don't add inside the hole where it attaches to the face plate. just follow the directions behind the jbweld pack.
Sep 08, 2009 | Pioneer DEH-P80MP CD Player
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
 Grubhead
Grubhead
