Question about Maytag Washing Machines
When i used my washer after 3-4 mins f3 e2 maytag front load washer , changed ntc but still same
Can not start
    Top Expert:
  • Maytag Master
  • 9,472 Answers
I am sorry to hear that you have error code F3E2. I know how upsetting error codes can be. I see here that for your Maytag washer, error F3E2 means there is a water temperature sensor error. Below is to test the error
WATER TEMPERATURE SENSOR ERROR:
1. If the water temperature sensor valve is out of range (23 degrees to 217 degrees F or -5 to 103 degree C) during the water-heating step of the WASH cycle.
Possible causes/procedures
a. Unplug washer or disconnect power
b. Make sure that connections to water heater and CCU (TH2 & HE2 cavities) connectors are not broken or with wires detached, and that connector internal pins are visible.
c. Check continuity from the water heater sensor (black wires to CCU (TH2 cavity) Connector.
d. If the continuity diagnosis failed, the Main Harness must be replaced.
e. Check the resistance of the heating element.
f. Check the resistance of the water sensor.
g. Plug in the washer or reconnect power.
h. Verify the washer operation by running the Diagnostic test.
i. After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
Below is the diagnostic test. I have it in two halves so you can read it best that way.
If you will submit your model number I will be able to help you further.
Posted on Nov 26, 2014
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
praky16
  • 744 Answers
SOURCE: ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
Posted on May 24, 2009
SOURCE: maytag front load mfw9600sq0
Hold down the end of cycle button for about 3 seconds.
Posted on Jun 22, 2009
  • 327 Answers
SOURCE: Samsung washer front load willnot rinse - no water
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
Posted on May 31, 2010
  • 44 Answers
SOURCE: MY GE front load washer stops at 45 min 35 min
I had the same problem. Mine ended up being a cut in the pressure switch hose. Here's what I would do to troubleshoot:
1) Clean the filter down bottom one more time. Run a basket-clean cycle and make sure that the drain pump is working. If so, then move to step 2.
2) Do a diagnostic test. Here's some graphical instructions on how to do it:
Grab the codes off the t02 error codes test. There is a reference manual for the codes in a plastic envelope behind the bottom access panel on the front of the washer (panel below the door) -- remove the 3 screws then pull out from bottom. Lookup the codes and see what they mean.
Mine was E22 -- which indicates problem with pressure switch.
3) Do the t06 basket test. If it fails, then open up the top of the washer to check the pressure switch and hose:
Twist the pressure switch 90 degrees clockwise toward the spring to release it. Undo the hose clamps and blow down the hose. Blow into the pressure switch to make sure a contact isn't stuck. I took the bottom panel off the washer and disconnected the other end of the pressure tube from the bottom of the tub. Once disassembled, I blocked the end with my finger to see if the hose was punctured -- sure enough it was. I taped it and reassembled. If after repairing and blowing out, if you still have problems, replace the pressure switch ($60 on Amazon).
Posted on Jul 27, 2011
What do the error codes F3 E2 mean on my Maytag 2000 series front load washing machine?
F3 E2 is an indication of a water temperature sensor (NTC) error, or heating circuit failure. Check the water temperature sensor and check connections to the water temperature sensor.
Several people having this error needed to repair one of the wires to the sensor. - "There were 2 black wires that go to the water temperature sensor. The wires passed through 2 tie wraps that bonded them to a flange off the bottom of the washer drum. They were wrapped with electric tape inside the tie wrap. Prior to joining the bundle of wires that went to the motor, there was one more tie wrap around the 2 black wires. At this tie wrap there was no electric tape to pad between the wires and the tie wraps. One of the wires was nearly severed.
I replaced the wires. Tie wraps should not be used. They are often too tight and crush wires. Especially in a device that inherently has LOTS of motion."
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/484867-maytag-washer-mhwe201ywoo-error-code-f3-e2.html
Feb 15, 2017 | Maytag Washing Machines
My whirlpool front loader door won't open f3e2code
the door lock may need to be changed as door safety is not unlocking so door not opening
Dec 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Wfw9050xw00
You should check the hot/cold water from wall to the inlet of washing machine, make sure it all are corrected. I came across the case that those hose were reversed from the first installation but the owner was never use hot water until the next owner faced the issue. Else, the control board need replaced.
Oct 05, 2013 | Whirlpool WFW9050X Washer
F3 E2 error code on my Maytag washing machine
I just had the same problem with my MayTag washing machine - F3 & E2 error codes.
I cleaned out the drain trap then proceeded to remove the top and rear panels to check the Temperature Sensor. The sensor was tested with an Ohms meter and found to be working properly.
I went over the wiring from the Temp Sensor and found that both black wires had been 'cut' under one of the zip ties near the bottom of the washer.
I had to reconnect them with marretts and presto; the washer works perfectly again. If you encounter this same problem - be diligent in going over the wiring. I missed it the first time around.
It's an easy fix for anyone who can strip a wire of the plastic coating.
Good luck :)
Feb 23, 2013 | Maytag MAH6500 Neptune Front Loading...
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hello, I'm getting and Error Code F24, does anyone
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. The part number is 8181705. Refer to the parts illustrations under the "Tub and Basket Parts" heading for item 26 as a pictoral reference to assist you in locating the sensor on your washer.
If you have any questions, please let me know. I hope this helps you.
Dec 08, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Sep 27, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
241 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
