Question about Staples Tools & Hardware - Others
My Hitachi N5008AC2 11mm stapler will only sink 2 inch staples 1/4 inch. I have had it completely apart...looks brand new...bought at auction with box of 10,000 staples and only about 100 are missing
Gun looks new...had it completely apart and everything looks good...just wont sink a 2 inch staple more than 1/4 inch deep. Fires week but retracts piston strong. 100 psi air pressure
Did you look for a clog in the air passage inside the gun when you took it apart?
Posted on Jan 10, 2015
5 Suggested Answers
  • 13 Answers
SOURCE: i have rebuilt my staple gun all new seals new
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Posted on Mar 14, 2011
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Posted on Jun 28, 2009
SOURCE: setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Posted on Apr 27, 2010
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
Our staples won't go all the way through . We
You didn't list the make and model of your stapler but if it's not driving the staples flush with the surface here are some possible causes:
1. The wood; If you are driving long staples into hardwood or knotty lumber you may have to use shorter staples to see how they set.
2. Stapler settings; Turning the air pressure up isn't the answer to driving staples deeper, it is only harder on the stapler. Most staplers work in the 90 to 120 psi range. The lower pressure you use the longer your stapler will last. Check/adjust the depth of drive control on the stapler to determine where the top of the staple is driven to.
3. Broke stapler; If it's not driving them to the proper depth but the level they are driven to is consistant, you may have a damaged piston o-ring/seal or the end of the driver is broken off. You'll have to go into the gun or take it to a service center to check these things.
Mar 04, 2012 | Air Tools & Compressors
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
The side of the staper lists 3 different staple sizes, does it really take all 3? (1/4, 3/8, 1/2 inch)
Samantha, Yes. These sizes are the lengths of the legs. They are all the same size wire, bent into the same width of "U". Yes, it will take all 3, but you have to buy the right type. When you buy staples, look for compatibility with this brand & model stapler. By the way, if you a stapling something thin to something substantial (such as paper to wood), use short staples. Otherwise you will have difficulty getting the staple to penetrate the wood sufficiently for the staple to lay flat. Good luck, Al K
Dec 08, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Cant get staples into it!!!
Sue, First, confirm that you have the right size staples. They are sized in two dimensions - width and length. The most common width sizes are T50 and T35. Your stapler and your pack of staples should have a number such as this. Your stapler will accept staples only of the correct width but of various lengths. The lengths are given in fractional inches - 3/8 inch and 1/2 inch are common.
But perhaps your problem is how to open the stapler. It does not swing open like a stapler you would use for papers. Instead, it has a sort of spring piston that has to be removed from the back-end of the stapler. If you lay the stapler down flat on the table so that the hinge of the handle is at the upper left corner, then what I am calling the back-end of the stapler is the lower right corner. Pick up the stapler so that you are looked directly at this back-end. There is a small metal square at this corner that is spring-loaded and is held in place by a little hook. Push in on this metal square as you move it up (or is it down?) to disengage the hook. Now the piston will pull out easily. Put your staples in the hole (they will only go in one way) and replace the piston. I hope you found this helpful Good luck!
Aug 19, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
My Swingline Stapler Model 51110 electric stapler no longer staples. The staples will not move forward and it just does "blank" stapling. Also, it goes off on it's own all the time running stapples...
I have the same issue; however, there is some resinous material that came out of it as a result of my trying to figure out why it wasn't stapling anymore. Anyone know where I can take it for repair?
Aug 05, 2010 | Office Equipment & Supplies
Tools & Hardware - Others Logo
196 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
