Question about Samsung Refrigerators
Remove samsung icemaker - Samsung Refrigerators
  • 24 Answers
You really need to actually pose a question. Such as, "My Samsung fridge model# 1234 is not making ice, how do I repair it?" That being said, try to find your owners manual for the device. If it is not available, find the model number on the fridge. It can be on the back, inside, or behind the front grill. If you know where it was purchased, you can go there and ask a salesman to give you the model number.
Once armed with the model number, we can go to the manufacturers website and get part numbers for the parts in question. Also, we can find either written instruction on how to troubleshoot that model, or a Youtube video. Most ice makers can be repaired for less than $100.
You just need a model # ...
Posted on Nov 26, 2014
Where is the reset button on my samsung refrigerator ice maker?
There is a test button on them if icemaker is in botton draw freezer section button is located on the bottom front on the icemaker its a small square button. If its the icemaker in frig section button on the right side on icemaker it is rectangular rubber coated hold about 10sec
Feb 14, 2017 | Samsung Refrigerators
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Samsung RF263 icemaker not filling with water
the fridge has an electric solenoid valve to let water in (just like your clothes washer) it is located where the water line goes into your fridge at the bottom in the back find,check, clean or, replace it.
Dec 03, 2013 | Samsung Refrigerators
How to remove samsung imc701 icemaker from refridgerator
Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
My ice maker makes a popping noise when it getting ready to dump the icecubes..pops ten times then deposit ice into ice bin. is this a problem that needs attention?
...known problem with the samsung icemakers. Need to order a new icemaker. The new icemaker should come with a new control board with upgraded firmware.
Sep 29, 2010 | Samsung RS2630SH Side by Side Refrigerator
My Samsung Space Icemaker makes ice very slowly. I keep hearing a click-click-click and maybe a few cubes come out. I have taken the white box inside the icemaker loose but not disconnected it. I think...
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
Sep 26, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
My samsung model #RS2578BB AUTOMATIC ICE MAKER IS NOT MAKING ICE PLS ADVISE
TOOLS NEEDED:
Eyes (fair to good shape)
#2 phillips screw driver
Flashlight
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker worked: ICE SENSOR MAYBE BAD> ORDER NEW ICEMAKER IF THE ICE DOES NOT EJECT AFTER 4
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
THE PROBLEM COULD BE either: ICEMAKER or Main PC Board
I would order a Icemaker assembly first since it is the least expensive.
1-800-Samsung
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
101 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
