Question about Dell Dimension E510 PC Desktop
When I leave my computer, I come back to a blue screen with an hour glass. I cannot do anything except manually shut down the computer.
    Sergeant:
  • 236 Answers
Assuming that you are not doing anything with the computer and leaving it idle (not running any programs besides background programs such as anti-virus) you may want to check your power connections. Usually when a computer freeze like that is caused by a power flux somewhere. It could be the power supply that is turning faulty due to a bad capacitor. May want to try it out with a good surge protector or a different outlet first before looking into the power supply.
Posted on Nov 25, 2014
3 Suggested Answers
four ace
  • 3 Answers
SOURCE: My computer suddenly shuts off then a black screen
ok first check to see if the power and video cables are attatched firmly. this was the problem with my computer and if u attached a new object to your computer remove it this also causes a computer not to turn on
Posted on Jun 05, 2009
fathitkf
  • 1871 Answers
SOURCE: computer shut down before logged off. now a blue
If it's blue screen with a lot of writing , that means hard disk failure is immenent , so backup your data and take it to the service .!
Posted on Jan 20, 2010
Picture has a yellow tint. It's from an old video game that ran over 12 hours a day. Has new bulb. Except for the yellow, works fine.
Hello there:
The best way to describe this is what is called screen burn in.
this is very common on screns that have games or pictures that arre displayed for long periods of time without being shut down just like on a computer screen when a screen saver is not used .
there is nothing wrong with the bulb.
the yellow that you are seeing is actually burned into the glass part of the projector and the lense
so if you can and feel like you can dissasemble the projector dissassemble it and locate the glass and see if you can get the yellow tint that will be on the glass and the lense off by using some rubbing alcohol and a cottomn swab
But if it wont come off you will have to replace the lense and the glass ok
Hope this is very helpful for you
Best regards Michael
Jan 18, 2010 | ViewSonic PJ501 Multimedia Projector
Craig 4gb mp3 model cmp616f does nothing but blink hour glass
left craig mp3/video player model cmp616f on while disconnected from computer over night. connected to computer next day seen hour glaas 2 or 3 seconds then craig blue screen . it connected to computer and stated charging again seems to have reset its noon now dec 28 2009 ill post again results when fully charged and try to use.
Dec 28, 2009 | Craig CMP168C MP3 Player
Mp3/mp4 player stuck on hour glass
me to i just turn it on the and a blue screen with a hour glass copmes up.
Jun 22, 2008 | Audio Players & Recorders
Blue screen - kmode exception not handled - ntoskrnl.exe
Did you install anything on your computer right before this happend to you??? Usually when this Dreaded Blue Screen comes up its a hardware issue, You may have installed Memory, USB, ECT... check that out and remove some of your memory first and see if that helps you out any. try also a F`12 or F8 start. see if that helps you out any, Get back to me if you have any other Questions Thanks Bear001
Jun 21, 2008 | IBM Think Centre A50 P4 (841923u) Network...
Computer shuts down with Flt. Sim 09
Hmm. Does the screen flash blue before it shuts down? And does it shut down or restart?
Mar 29, 2008 | Computers & Internet
Acer Aspire 9300-3655: Shuts Downs When Idle
It sounds like you are getting a blue screen error.
Most of the time these are resolved by manually running CHKDSK /R
To check for a blue screen error, right click on "My Computer"
Go to properties, click on the "advanced" tab, Click on the "Startup and Recovery" settings button.
Under "System Failure" uncheck "Automatically Restart"
Now if your computer is restarting do to an error then you will see the blue screen.
The important information to give back is the 0x000000** part which is displayed.
Mar 14, 2008 | Acer Aspire 9300 Notebook
I pod only turns on then shuts down and comp doesnt reconize it
Your battery is dead!!! Try to recharge with USB adapter!!! If that doesn't work you need to change battery. Give me some spec. about your MP3!
Jan 25, 2008 | Apple iPod nano 3rd Generation
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue...
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Aug 21, 2007 | Sony KV-35S36 35" TV
Dell Dimension E510 PC Desktop Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
