Question about Furniture
How do I fix a 2 Whirlpool/Danby WWC287BLS 2 zone wine cooler with 1 zone that operates correctly at set temperature but the other zone gets way too cold (36 degrees) and the compressor keeps running.
    New Friend:
    Problem Solver:
  • 13 Answers
Check to see if the thermostat is possibly being blocked by something. If one zone is working correctly there must be an obstruction or problem with the thermostat sensor.
Sorry can't be of more help
Posted on Nov 29, 2014
Testimonial: "Thanks for response. Pulled all control apart, disconnected and reseated all connectors at the Control unit and at the compressor solenoid valve. Then tried running again for a few minutes everything ran correctly, I could hear and see the temperature regulating within a degree or two of the set temp in both zones the it made a click at the back and started overcooling. I tapped the solenoid valve (not to hard with a screwdriver handle) and it regulated for a few more minutes. Think my Solenoid valve is sticking and I'm guessing the would require a refrigeration mechanic to drain the system, replace the valve, then recharge and set the pressures. Beyond my ability. Thanks Michael"
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
  • 218 Answers
SOURCE: wine cooler
Try this website. http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=224777abd6c75c24622a757a6f5ff1ba&q=Magic+Chef+MCWC30MCG&e=1
Posted on Jul 27, 2008
  • 159 Answers
SOURCE: I have a danby wine cooler that is running hot. I
if the motor are running the gas level are too low . if the motor are not running check the thermostat. if there are power by the motor and stil not running then it is the motor
Posted on May 16, 2009
Will not cool to correct temperature as set
check the air exchange under and at back of unit if its to hot or dusty will effect how unit preforms if good and clear possible thermostat or motherboard circuit last would be low on freon
Aug 16, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
The left side exterior gets too hot to touch at times,is this normal?
Yes it can get quite hot, remember there is a compressor running in there.
Aug 15, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Temperature Light Bling
http://www.danby.com/cms/documents/pdfs/en/DWC114BLSDD_EFOM_%28DM%29_FINAL.pdf
set the temp higher,or check front exhaust vent,"a low temp means it is too cold,adjust the thermostat to a warmer temp"
Mar 14, 2015 | Danby DWC114BLSDD 38 Bottle Dual Zone Wine...
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Need to reset temperture
Please have a look at page 4 of the product manual where step-by-step directions are provided for setting your desired temperature.
http://www.danby.com/cms/products/en_manual/DWC283BLS_%28web%29.pdf
If you have any further questions, please do not hesitate to contact Danby Customer Service via 1-800-26-DANBY
Hours of Operation Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Jun 03, 2012 | Danby DWC283BLS Wine Cooler
How do u set temp in a Danby wine frig?
May 05, 2012 | Danby DWC283BLS Wine Cooler
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Furniture Logo
291 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
