Question about Brother MFC Office Equipment & Supplies
How do I reset counter when replacing drum unit on printer DC-7065DN Instructions say to press GO button for 4 sec but no GO button and no LED lights
  • 6 Answers
In order to fix this
1. Turn on the machine before you start.
2. Open the front cover.
3. Press Clear or Clear/Back on the control panel.
*Note: It could be different to have the format of a control panel, but there is a button for Clear orClear/Back on the right side of the LCD screen.
4. Follow a direction according to your case.
- For the numeric keypad, Press 1 to reset the drum counter.
Posted on Nov 25, 2014
jaylex
  • 417 Answers
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Posted on Feb 04, 2008
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
HobbesVT
  • 3 Answers
SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 03, 2009
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Posted on Aug 29, 2009
SOURCE: reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Posted on Oct 26, 2009
Drum light keeps appearing
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover
Mar 31, 2010 | Brother HL-2040 Laser Printer
How do I reset drum counter on brother printer HL5250dn
Hello. if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Regards, Joe PS: kindly rate my answer. Thank you.
Jan 28, 2010 | Computers & Internet
Drum light flashing in spite of new drum unit and new toner cartridge
common problem.
  1. Close the front cover.
Caution
    Reset the drum counter only when you replaced the drum unit with a new one.
Dec 30, 2009 | Brother HL-2040 Laser Printer
Drum light blinks
1. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until
2. The Drum LED continues to blink if the drum counter was not reset when you replaced
the drum.
a. Open the front cover of the printer.
b. Press and hold down the white button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the
button.
c. Close
Dec 10, 2009 | Brother HL-2040 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Aug 03, 2009 | Brother HL-2040 Laser Printer
How do i reset the dr360 drum unit
the drum.
b. Press and hold down the white button (shown as blue in the image below) for
button.
c. Close
Jun 10, 2009 | Brother HL-2040 Laser Printer
Dr 360 reset procedure
the drum.
button.
c. Close front cover
Feb 02, 2009 | Brother HL-2040 Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Make sure that the Drum LED is now off.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Brother printer Hl 2070. Toner light is on , changed the toner , still yellow light is on and I can't print
From Brother.com: Description:
Caution
Apr 06, 2008 | Office Equipment & Supplies
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
