Question about Fisher Washing Machines
I have a fisher Paykel AquaSmart washing machine. ti throws an error code when trying to fill with water. From right to left the buttons 1,2,4,8 are lit up. Anyone who knows what these codes mean?
It started when it would no longer agitate. It still spins and rinses. The only bitton that lets some water go in before stopping and showing the error code is the sheet cycle. Thank You Ron Hattenburg
    New Friend:
  • 76 Answers
Here ya go Ron, your error codes and what they mean. Good luck!
Fisher Paykel AquaSmart Top Load Washer Error Codes Sears PartsDirect
Posted on Nov 25, 2014
appldoctom
  • 311 Answers
SOURCE: fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Posted on Dec 31, 2008
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
  • 41 Answers
SOURCE: MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Posted on Jan 31, 2010
I have a fisher and paykel top loading washing machine and I get an error code 9.
javascript:;To size set a L.C.D AquaSmart™ machine:
1. Press and hold the left
SCROLL
button, then press the
HIGH EFFICIENCY
button until two
beeps are heard.
2. Press the
SCROLL
button to select the machine size (600 for WL70, 650 for WL80).
3. Press the
POWER
button
Apr 12, 2015 | Fisher and Paykel Aquasmart wl80t65c
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
Error code 49 on my aquasmart what is this at beginning of wash it doesnt fill up with water
Code 49 is a cold water valve is faulty.
Action: check the valve coils are not faulty (open circuit
Oct 25, 2010 | Fisher and Paykel WA37T26G Top Load Washer
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Washing Machines Logo
158 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
