Question about Exceed-RC Toys
My Dynamite is having some problems and i have no idea whats wrong it will run drive at about quarter power then the throttle goes out but still have steering so i have to turn it off and back on a
Its brushless and running stock 8.4 battery and 2.4 radio
    Problem Solver:
  • 8 Answers
What sort of battery are you using ? if it is the original stock battery which is Nimh 8.4v, it is possible that this has formed a memory and is failing . change to Lipo 11.1v 2s 2000Mah or above and you should see a significant change in performance
Posted on May 08, 2017
  • 113 Answers
SOURCE: Runs for about 2-5 minutes and then down to
Sounds to me like the battery is going out on it. Not sure how much a replacement battery is, but it is where I would start.
Posted on Aug 04, 2009
SOURCE: I just purchased a 1/16
I have the same problem with my mini vxl slash sometimes and for me anyway I first unplug the battery, plug it back in, set the esc and then rotate the throttle adjustment on the transmitter reverse and then foward and for me that seems to work everytime. Dont know for sure if this is the same problem that you are having but I hope my answer helps...
Posted on Jan 19, 2011
Benimur
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
Shuttle83
  • 1139 Answers
SOURCE: Alpine pdx-1.1000
Hello Briankt69,
Ot two issues, First the AMP is going into a protection mode this means that it is drawing too much current. As netrecov said you need a capacitor, this will oppose the rapid current draw, by allowing the voltage to remain constant. However I would also sugget that you rewire the setup to manufatures specification and make sure that all grounds and supply leads are installed properly. Taking into mind the the 4awg wire has less cross sectional surface than the 2 or 0 AWG wire causing it to have more resistance this is power loss in this case (follow the specifications).
I hope this helps
Thank you,
Shuttle83
Posted on Apr 21, 2008
bbtoast
  • 319 Answers
SOURCE: Honda Civic Steering problem
Hi Dan
You did not indicate whether you checked the fluid level for your power steering. Please check this first. Please read your owners manual for specific instructions!
You may be low on fluid.
The next step would be to check your engine belt. The power steering pump is driven by a belt. It is possible that you have a loose or worn belt that is not able to turn the pump sufficiently at idle, but when you rev the engine higher, the pump produces sufficient power. One way to test this is to rev the engine, then try to turn the wheel, see if you notice any difference. Let me know.
Brian
Posted on Jun 16, 2008
Hyundai sonatas was parked after normal drive, now will start and shift gears but won't get gas. I suspect a cat got in it and loosened a hose as one did our other car, I can't find where, any ideas
Not understanding what your asking, if it runs and shifts gears then it's getting gas, if it's acting like no power I would look for vacuum hose or considering the fuel pump going bad. Fuel pumps can be interment but eventually will fail. If tank is full probably work ok less than a quarter tank and the pump is out of the fuel and heating up.
Nov 07, 2015 | Hyundai Cars & Trucks
I was driving at about 70 mph all of the sudden I could no longer accelerate. When I step on the gas pedal nothing happened. I had to coast over to the side and catch a tow. The car will start fine, idles...
These vehicles use a "drive by wire" system. That means there is no longer a cable to pull the throttle open.
if something goes wrong they automatically default to 0% throttle for hard faults.
You either had a sensor go bad, or the motor that opens the throttle.
Oct 23, 2013 | Buick Rainier Cars & Trucks
My emachine t1831-07 keeps getting stuck on green screen w3hen trying to install windows 7 really @#%@%#@#% annoying 2 weeks ive been patient any suggestion on how to fix or place to get dynamite and have...
www.dynamite.com might still sell what you want :> Just kiddding!
Try a complete wiping of the hard-drive unless you are doing an upgrade, you will lose all data on the drive. If that doesn't work, you might not be running enough ram memory for 7 to run cleanly on you machiine, go ahead and upgrade.
Hope this helps!
Sep 18, 2013 | E-Machines T Computers & Internet
MY 2004 SANTA FE WILL NOT START IF GAS LEVEL IS A QUARTER TANK OR LOWER AND ALSO WHEN I FILL UP WITH GAS. THE CHECK ENGINE LIGHT DOES NOT COME ON! SO NO ONE CAN TELL ME WHAT MIGHT BE WRONG. ONCE IT SITS...
The Check Engine Light does not have to come on for someone to find out what is wrong. A shop may have to have the car for a few days so they can run some tests on your fuel and ignition systems. They will most likely have to drive the car/run the engine to duplicate the symptom so they can catch it while it is malfunctioning. Intermittent problems can be very elusive, but they can be diagnosed with a little patience. The level of your fuel gauge most likely has nothing to do with your starting problem.
Jan 22, 2011 | 2004 Hyundai Santa Fe
New crf250r breaks down at high revs since new
Thats not normal. You could get a bike off the show room floor and completely skip the break in period and it would run wide open. If your bike wouldn't rev past quarter throttle there is something wrong. With a blackened silencer and a motor that dies at quarter throttle I'd say you've got a problem with your injection system flooding your motor with fuel. I run 3 warm up and cool down rotations and go ride like normal. After 4 tanks of fuel your bike is more than broken in. If you aren't familiar with the injection system take it to the dealer and get someone to look at it. If you bought it new it should be covered as a manufacture defect.
Jul 25, 2010 | 2005 Honda CR 250 R
I have a '06 chevy aveo that won't hardly pull it's self down the drive way. check engine light came on then started blinking. now it don't blink just stays on. car has NO power and only has 63,000 on it....
have 'sort of' the same [problem on wifes car. it lost power while driving and she had to pull over and shut the car off and restart it.
I pulled the codes with a OBD2 scanner and came up with 3 codes, P2106, P2110 and P2135.
Last one is for Throttle/Pedal Position Sensor/switch A/B voltage Correlation, figure that must be the TPS as its known. Checked on line for it and found several for around, get this, 181 dollars!!!!
Other codes were for Throttle Acuator Control System Forced Limited RPM.
So I'm figuring a new TPS "might" fix the problem but $180 is not easy to let go of but may have to.
First, do as first post says, or take it to a Checker or AutoZone or someone like that in your area and have them run the OBD2 scanner on it to see what codes your car throws, then you have an "idea" of what may be wrong, sometimes those codes will not send you to the correct area. Just replacing sensors can get expensive only to find out it is caused by a vacuum leak or throttle body is bad (those are real pricey).
Check with someone that get retrieve the codes for free first.
Mar 27, 2009 | 2006 Chevrolet Aveo
Toys Logo
230 people viewed this question
Top Exceed-RC Toys Experts
jasiel murphy
Tejodhar Atreya...
Tejodhar Atreya...
Mike Darragh
Level 1 Expert
Are you an Exceed-RC Toy Expert? Answer questions, earn points and help others
