Question about HP Office Equipment & Supplies
My HP PSC 4500 printer makes a loud knocking noise when first turned on which goes off after a few seconds and printer woorks okay
  • Ken Watson
    Ken Watson Dec 01, 2014
    Thanks Garyabbs but the noise isn't the usual noises heard when the printer is turned on. I am well aware of those sounds after using the printer for a number of years. The clacking sounds are something new and quite a bit louder than the normal sounds you are suggesting.
    Novelist:
  • 140 Answers
OfficeJet Printers have a "spittoon" in which a rubber pad is used to wipe the bottoms of the cartridges to maintain a clean jet nozzle area. To find this, the unit will go to it's home position, "bump" that side where the spittoon resides, to confirm it's home position, then wipe the cartridges before its ready for use. In other words: "That's a normal noise for this model of printer". It will happen every time you power it up or wake it from hibernation mode with a print job.
Posted on Nov 26, 2014
  • Ken Watson
    Thanks Garyab9ss. As I have owned and used the printer for a number of years I am well aware of the normal warm up sounds when the printer is turned on but the sounds my printer isn't anything like those you are suggesting. These 'clacvking' sounds are far louder than those you are suggesting and go on for far longer. It is something mechanical which does go of after a while but goes on for longer than those you have suggested. I am leaving the printer switched on permanently and allowing it to goe into 'power save mode'. Not happy doing it but it is saving it from ripping itself apart. Thanks for helpful suggestion.
CoachTim
  • 202 Answers
SOURCE: Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Posted on Mar 06, 2007
CoachTim
  • 202 Answers
SOURCE: hp psc 2175 all in one making knocking noise
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&cc=us&dlc=en&product=90809&lang=en Here is the HP site for any extra info you may need. ISSUE: Sometimes when printing out, the carriage makes an abnormal noise or its movement is erratic. SOLUTION: To solve this issue, follow the steps listed below: NOTE: The images and descriptions showed along the document might be slightly different depending on your HP All-in-One model. 1. Clean the unit front and back rollers. To do so, follow the steps listed below: 1. Disconnect the power cord or power supply from the rear of the unit. 2. Open the print carriage access door. 3. Remove the rear door and check it for damage. 4. Make sure that the paper rollers inside the rear access door rotate freely. Please clean them using a lightly moistened cloth. 5. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. 6. Allow the rollers to dry completely, and then close the rear access door. NOTE: Make sure the rear access door is correctly closed and placed. 7. Through the previously open cartridge access door, clean the front rollers with a lint-free cloth lightly moistened with distilled or bottled water. Please rotate the rollers with your fingers to clean all the way around. 2. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. WARNING: Do not lubricate the rod. 3. If noise is located at the paper path, it may be caused by ink, dust or other residues stored over the pinch rollers. Please, clean the pinch rollers by using a cloth lightly moistened with alcohol. 4. The edge of the pitch rollers must be cleaned too. To do so, use a small drop of alcohol. This will remove the ink and will solve the issue. (see detail in the image below). 5. Clean the carriage contacts and the capping station. To do so: 1. Connect the power cord to your HP All-in-One product, and turn the unit on. 2. Lift the front of the HP All-in-One product just above the paper output tray as shown below. The print cartridge capping station will lower to allow access to the print cartridges. 1 - Print cartridge latch 2 - Capping station 3. Gently pull up the print cartridge latch front to release it. The latch is spring loaded and will spring upwards. Slowly raise the latch instead of letting it spring open. 4. 5. Remove each print cartridge by sliding it out of its socket, moving it toward the front of the HP All-in-One product. Do not try to pull it in an upwards direction. NOTE: If the print cartridge cannot be slid out, verify that the latch is raised, and the HP All-in-One product is on. If it is not possible to remove the cartridge, too much time may have passed since it was opened and the capping station may have raised again. Close the print carriage access door, wait five seconds, and then open it again to lower the capping station. 6. Extract the cartridges and clean the copper contacts with a watered lint-free cloth 1 - Copper-colored contacts 2 - Ink nozzles (do not clean) 7. Disconnect the power cord from the HP All-in-One product. 8. Clean the electric pins placed in the front of the print carriage using a lightly moistened cloth. 9. Using a dry cloth, clean the ink stored inside the capping station sponges (see the image below). 10. Mop up the electric pins completely, and connect the power cord again. 11. Turn on the unit, reinstall the cartridges, and close the print carriage access door. 12. If the noise issue remains unsolved, please perform a Power Cycle on the unit following the steps below: 1. Turn the unit off. 2. Unplug the power cord from the unit. 3. Wait 30 seconds, and then re-connect the power cord to the unit. 4. Turn the unit on. 13. If the issue persists, the unit may need to be reset. Please, consult the HP All-in-One Products - Performing a Partial Reset of the All-in-One document to learn how to do it. Additional steps (only for PSC 1100 & 1200 Series All-in-One products HP PSC 1100 & 1200 Series All-in-One products may be affected by this issue, due to the friction between the printing carriage and the paper. Please, print a couple of pages full of black text in Normal mode, and follow the steps listed below if the printed text looks like the image below: 1. Print a Self-Test Report and then, check the quality of either the text or the color bars. Follow these steps to print a self-test report: 1. Press and hold the Cancel and the Color buttons at the same time. 2. Release both buttons. 3. The Self Test Report will be printed. 2. If the media does not fit the weight specifications (see table below) or if paper is curled, then this may prompt the bottom of the ink cartridge to come in contact with the media. If this happens, the print will smear and the cartridge may become damaged. HP PSC 1100 & 1200 Series Type Paper Weight Plain paper 70 to 90 gr/m2 (20 to 24 lb.) Cards Up 200 gr. (110 lb.) Envelopes 75 to 90 gr. (20 to 24 lb. max.) Transparency Film N/A Labels N/A 4 x 6 Photo 236 gr/m2 (145 lb.) Custom Media 34 gr/m2 (9 lb.) 3. Make sure that the Paper Type is correctly set to either Plain or Photo. 4. Run an alignment of the print cartridges. To do so, follow the steps below: * HP PSC 1100 Series: 1. Turn on the HP PSC 1100 Series product. 2. Disconnect the USB cord from the unit rear. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: NOTE: The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds. 1. Press and hold the Cancel button. 2. While holding the Cancel button, press the On button. 3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 4. Press the Cancel button again. 5. Press the Resume button. 6. Press the Paper Type button. 7. Press Color Start Copy. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On light stops blinking. 5. Re-connect the USB cord to unit rear. * HP PSC 1200 Series 1. Turn on the unit. 2. Disconnect the USB cord from the unit. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: 1. Press and hold the Cancel button, and then press the On/Resume button. Then, release both buttons. 2. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 3. Press and release the Cancel button again. 4. Press and release the Copies button. 5. Press and release the Paper Type button. 6. Press and release the Start Color Copy button. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On/Resume light stops blinking. 5. Re-connect the USB cord to the unit. 5. Close the cover and press the Scan button. Wait until the alignment is finished. The On light stops blinking when the alignment is finished. Let me know what happens. Good Luck, Tim,
Posted on Mar 15, 2007
SOURCE: HP PSC 2410 All-In-One InkJet printer default settings
Please can i obtain advice on how to reset my printer, as i am getting funny noises from it and nothing else.
Posted on Oct 14, 2008
efs_perpends
  • 1996 Answers
SOURCE: hp psc 2400 scanner motor stuck in repeating motion
Unfortunately, in this case HP's support site doesn't offer a lot of help. See here. or here.
This article will get you part way there if you decide to dig in and try to work on it yourself.
If you want to talk to the HP techs, see here.
If you're interested in reading a forum full of posts about the same issue, see here. and here. Read far enough and you'll see some solutions proposed, some of which may work in your situation.
Apparantly, if the scanner doesn't correctly read an encoder strip on the underside of the glass, which causes the motor to keep engaging even when the scanner bulb is fully retracted, and the belt starts slipping gears, causing the noise, etc.
And when the code isn't read, the alignment fails and the printer won't work. That's what I remember from the last time I looked into this, anyway.
Good luck with it...
If you don't feel comfortable yourself, perhaps some able and competent friend will be willing to have a look.
Otherwise, you'll have to get it serviced.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 28, 2009
Semi-Driver
  • 434 Answers
SOURCE: loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Posted on Dec 28, 2009
My HP PSC 4500 printer makes a loud clicking sound when turned on but goes off after a few seconds
Mechanical failure : it's either the belt that drags the print head or the cogs powering the belt that are skipping due to wear.
It can be repaired, but unless you can find a local service that will do it on the cheap, you're better off buying a new one
Nov 24, 2014 | HP Office Equipment & Supplies
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
Cranks but engine makes grinding noise
From what your saying it sounds like your fly wheel .or your starter's sylinoid may have some broken theeth.chech it out.
Dec 06, 2017 | 2000 Ford Escort
Hp printer photosmart c 4795
I don't have a photosmart, but I do have an HP OfficeJet J4680 that clicks sometimes. Check to make sure the ink cartridges are installed correctly. That's what is sliding back and forth when you turn it on.
Dec 17, 2011 | HP Office Equipment & Supplies
Loud clicking noise when turn on printer
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
My daughter pulled this long plastic strip out HP PSC 1210
Sounds like it is the guide strip that pushes/pulls the print carriage back and forth?
Sorry but it is not a repair easily carried out at home, if at all. If in one piece and not broken it might be re-introduced but the bottom line is you will most likely have to purchase new? Sorry. it might cost just as much if taken to a repairs?
Nov 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
Loud, knocking noises
your fuser is about to go...
happened to me last week
Sep 02, 2008 | Brother HL-5170 Laser Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
