Question about Dryers
My dryer error code e63
Changed the switch
  • Dryers Master
  • 3,382 Answers
I would suggest more information such as make and model so somebody has a chance of helping you. Different manafactures and different models have diffetent error codes and meanings to them.
Posted on Nov 25, 2014
My Frigidaire Dryer (Model #FASE7073LWO has a error "E63" listed on the window. What error is this in reference too?
I appreciate your post, Aeraci Los Fresnos!
From the information you have provided your Frigidaire dryer is providing an error code of "E63". The "E63" code stands for heater to earth has been grounded, this could be a possible issue with your heating coil or connector. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes this will help clear out any miscommunications. If you continue to experience an issue with the "E63" error code I would suggest consulting with a professional technician come out and provide an accurate diagnosis for repairs. Best of luck! -OOS
Feb 03, 2015 | Frigidaire Dryers
Error E063
Good Morning Friend,
I understand you are receiving an E63 code on your Frigidaire Affinity dryer and want to know what it means. The E63 code means that there is possibly something going on with the heating element or some wiring inside your dryer. This can also be a false code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Im getting the E63 error code,what does this mean and can I fix it myself ??? Any advice is greatly appreciated. Thanks, ...
The error code E63 is a high temperature warning:
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Oct 21, 2010 | Electrolux EIED55H Dryer
Electrolux dryer has code of E63
Hi
Thanks for using FixYa. Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 09, 2010 | Electrolux Dryers
What doe error code E63 refer to? thanks
"E63" error code means that your dryer thinks the temperature is too hot. Most of these units should still be under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board which involves high risky things to be done. So its safe to reach the company service technician to fix this issue.
Thank you!!
Jun 01, 2010 | Electrolux EIED55I Dryer
Electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Jan 02, 2010 | Electrolux Dryers
Dryer shows E63 error code? What is it? Should I call service?
Apr 11, 2009 | Electrolux EIED55H Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
