Question about Horizon Elite 5.2T Regular Treadmill Walking Belt
How do I troubleshoot a horizon 5.2t treadmill... Stops randomly and gives code e5.2 seems to stop more often when you try to use incline
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
ercupa190
  • 12223 Answers
SOURCE: Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Posted on May 06, 2012
ercupa190
  • 12223 Answers
SOURCE: My horizon t901 treadmill console display has stopped working any ideas ?
please adjust the REED switch, see the diagram attached, clean it+tight the connector very well, and test for open or faulty with DVOM
2) tight the ribbon cable for keypads
3) replace the batteries by new ones. and clean the contacs batteries very well.see the block diagram
Posted on Feb 18, 2013
Stuck in up position. Bought a new incline more and if it goes above 5, it will keep climbing and won't come down.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 24, 2016 | Horizon T61 Treadmill
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
I have a Horizon HTM 3000 treadmill which is stuck on max incline and require the incline calibration code.
hi, i also have problem with my horizon htm 3000, incline motor stuck.
did anyone know where to buy brand new incline motor?
and how much it will cost?
Nov 16, 2013 | Exercise & Fitness
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
Apr 19, 2012 | Horizon Quantum II Upper Control Board
I have a Horizon fitness CST3 and the belt stops running but everything else stays on. Do you know what is cuasing my problem?
How old is your treadmill? Has the deck been lubricated? Do you smell anything odd when the belt stops? Unplug treadmill, remove motor cover and check cables are all connected.
Oct 23, 2010 | Horizon Fitness Merit Fitness 725T...
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel to reduce the incline.
Sep 21, 2010 | Horizon Fitness Merit Fitness 725T...
The treadmill does not incline. Motor runs when the button is pushed but no movement.
Try Re-Calibrating 1st, here's how.
With the Treadmill off, press and HOLD the SPEED UP & STOP
keys, while holding the speed up & stop keys insert the Safety key (Magnet) release the speed up & stop keys. now press and release the stop key. now press the "incline up key" let the treadmill go to max incline,after it stops press and hold the "incline down key" let it go to minimum (completely lowered) you should now be re-calibrated.
Dec 23, 2009 | Epic 425 Mx Treadmill EPTL88105 !
Horizon Elite 5.2T Regular Treadmill Walking Belt Logo
54 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
