Question about Vision Fitness T9250 Deluxe Folding Treadmill
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
    New Friend:
  • 13 Answers
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Posted on Nov 26, 2014
How to fix E4 error
check the water tank flipper if broke it will directly cause the unit to not function and the E4 message will apper on the display screen.
May 26, 2014 | Soleus LX-140 Portable Air Conditioner
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
My Singer stylist 7258 is giving an E4 error code. It wont work at all, just give an odd sound and a high pitched sound then stops, flashing E4 on the display screen. It is only 2 months old and I live...
the brand new stylist I just bought at a thrift shop for $15.99 had a sticker on it stating, "Broken, you fix, parts in back"... I got the lady to get the parts in the back, which was the box it came in and all the accessories. Took it home plugged it in and E4 came up. I took of the nose guard with the one screw on the side, reached in and turned the coggs gently, viola, it works great.. The little servo or motor if you will got stuck when turned off in a zig/zag decorative mode. eazy fix, great machine,
hope this helps..
Michaelalan Quilting
Oct 26, 2011 | Sewing Machines
E4 Error in Hunday Split Ac
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
E4 error being displayed
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
Vision Fitness T9250 Deluxe Folding Treadmill Logo
338 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
