Question about Husqvarna Garden
I have husquavarna self propelled lamnmower and need to know how to remove belt covers to properly clean It is a model #96145001800
Blowing it out with air pressure
  • 84 Answers
Typically there are two or three 1/2" nuts underneath and then two or three 3/8 head screws on top. Remove those and you should be able to get it off.
Posted on Nov 27, 2014
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Posted on Jun 05, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 299 Answers
SOURCE: Wheels won't turn on self propelled mode.
remove the cover and check the belt
Posted on Sep 24, 2009
  • 202 Answers
SOURCE: rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Posted on Jan 26, 2010
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
TB210 Drive Engage Cable. Can not remove Front Cover.
Hi Chip, I too have a model 12AGA26E011 which has suddenly stopped being self propelled. I'm looking into how to remove the top cover so I can get to the belt and drive mechanism to determine what is amiss. If i have any luck I will let you know. obviously others that have posted here are stating the obvious but not answering your question. If you happen upon the solution please provide an update. Thanks! Doug
Jul 13, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt 6.5 -self propell belt came off..how do i put it back on
I assume the front wheels are the drive wheels. There is a cover over the belt, on top you'll see a plastic cover, if it drives from the bottom you'll have a metal cover under the deck. Eigther way remove that cover which ever one it is. This will expose drive and give you acess. They tend to collect alot of debri and rust clean before remounting or repacing belt.
Sep 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self-propelled doesn't work
remove plastic cover to access drive mechanism
check belt and remove debris and try again
Apr 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
SELF PROPELLED WILL NOT WORK
I would look at replacing the belt. they stretch and start slipping. also a proper cleaning and some belt dressing spray may take care of that.
Mar 31, 2009 | Garden
No suction
Flip the machine upside down and remove the four screws from the baseplate. Replacement should be fairly self-explanatory from there. If it's a self-propel model, note that the v-belt in the front WILL look loose normally, so it does not usually require replacement.
If you have a self propelled model, the belt you need ends in 035, if it's non self propelled it ends in 033.
Contact me if you need more assistance in changing the belt.
-R
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Garden Logo
53 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
