Question about Pioneer Elite DV-47Ai DVD Player
Dv-47i not diplay picture properly
Change the connections from RCA yellow to s video, plugged another device into that port on TV and it worked
  • Pioneer Master
  • 1,150 Answers
Hi Darrin
Obviously there is a problem with the RCA cable or socket. Yellow is the Video signal. S Video combines these into one cable.
For absolute best video performance try and use HDMI if available as this is the most modern means of getting High Definition Video & Sound from one device to another
Cheers
Posted on Nov 27, 2014
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
Firstly, CAN??, and then how do I get an NEC NLT-19XT1 television to work with a TEAC High Definition Digital Receiver HDB848 HDMI, please. Anyone know how? Appreciate all the help I can get. Thank
Id the TV Anolog or Digital? If it is analog, then the digital receiver must have RCA outputs to meet the TV's RCA inputs. To make an old analog TV work (meaning getting a picture), you have to check id the receiver has RCA or S-Video outputs. If so, then connect an RCA cable with yellow into yellow, red into red and white into white and then connect the same colors plugs to the yellow, red and white to the RCA inputs of the TV. Or, you can connect a S-Video cable plugs in the output of the receiver and the input of the TV, disconnect the yellow RCA plugs at both the receiver and TV sockets and leave the red and white cable for sound only, as S-Video has an improved video signal, therefore better picture quality. On the TV you have to select an AV input channel, like AV1 or AV2, etc. The same channels that you had used when you were once watching VCR tapes on analog TV. Hope this helps.
Nov 17, 2014 | Televison & Video
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
I can't get tv to change input so that my DVD
What is the brand and model of your TV? Usually, you just need to press the VIDEO button or VIDEO/TV repeatedly until you see your DVD on it. It depends on which port you connected your TV. Make sure that your DVD player is connected properly. If you are using RCA, make sure the yellow cable (video) is connected to the yellow port of your TV and your DVD player. And also make sure that your DVD player is turned ON. If it still won't work, try a different cable.
Oct 06, 2011 | Televison & Video
I am trying to install ROKU video streamer into my Sharp TV model 27KS300. Roku says to plug their red/yellow/white RCA cable into the video in ports on your TV. I do this but nothing happens. I am...
Yes these are the same yellow white and red ports that you would use to connect your DVD player. I believe this television has one port in the front and one in the back. I might be wrong but I believe video 1 is in the back and video 2 is in the front. If you have tried video 1 and video 2 making sure you have pressed the video/input button to select the proper one after connecting your Roku then you have done everything properly. Make sure to try a different RCA cable to make sure it is not the cable that is causing the problem. Also try the Roku on a different television because if it is working on a different television with the same RCA cable then you'll know that it isn't compatible with this particular television.
Apr 13, 2011 | Sharp 27K-S300 27" TV
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
Can only record sound not picture?
Make sure the Yellow RCA Cable is plugged into the Yellow port on the DVD recorder. People often try to plug these in without good lighting & will plug the White audio into the Yellow video ports. Also, check to make sure they are in the correct color ports at the TV as well.
Yellow = Video
White = Audio
Red = Audio
Another way to test the cable is to bring a smaller TV in next to the main TV. Use your RCA cables coming from the OUTPUT of your main TV that you want to record from & connect the other end of the cables to the INPUT of the smaller TV just to see if the cable is passing video. The cable could just be bad & you need to buy a new cable. Hope this helps.
Jul 17, 2009 | Panasonic DMRES15 DVD Recorder
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
Dec 06, 2008 | RCA G27647 27" TV
Get sound but no picture
Plug the yellow RCA cable into the Video Out on the 3 2 1 and into one of the Video In ports on the tv. Make a note of which port you plugged into. Then change the input selector to that video port on the tv.
Feb 16, 2008 | Bose 3 2 1 GSX System
Pioneer Elite DV-47Ai DVD Player Logo
51 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
