Question about Ook Picture Hanger Shield"
How do I hang a picture using picture hooks?
Nothing I don't know how to use them
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
You should have two 'pin' nails that hammer through the two nail guides at top. You picture will need wire hanger which settles into the lower hook part of the picture hook.
Posted on Nov 25, 2014
I want to attach a hook on my deck thru vinyl siding and there's nothing behind it. Should I use toggle bolts?
Better to get one of those hooks with sticky stuff on the back. Used for hanging pictures. Make sure surface is clean (alcohol) Different ones hold different weights.
Oct 10, 2015 | Dryers
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Kitchenaid difficulty removing whisk
It is not uncommon for gunk batter sugar eggs or other stuff to get up inside the attachment shaft of the mixer and if you don't use it for a while it can turn to glue. remember school flour and water = glue. well add some sugar and some eggs and "wallah" you got glue. How to fix? Get a squirt gun. yep fill it with hot water and squirt it up in the hook and loop portion of the attachment shaft let it sit for 5-10 mins and repeat a couple times. the beater should come off, clean the shaft and then the whisk soak the attachment portion in hot water and let soak to soften the gunk and the spray it out with the sink sprayer. hope that helps. There could be one other mechanical problem and that is the hook that the beaters hang on could be coming out and caused the attachment to jam up ther take a pencil or pen and while pressing the beater up see if the pin wiggles or wobble and most importantly goes back into the mounting shaft. let us know if this helps at all.
Sep 17, 2012 | KitchenAid Food Mixers
Analog
You will have to use the HDMI input to go digital. Without looking at the set I don't know what type of hookups you have in the back but there should be numerous ways to hook up to the digital link. You may also need an adapter depending on what kind of hook - up you have. Let me know if you have any other problems.
Gillight
Aug 27, 2012 | ViewSonic N3752w 37 in. LCD TV
Last month we bought a new Toshiba 46SL412U LED TV. We would like to hook up our digital camera to it to see pictures of a recent vacation. We don't know how to do it. All that came with the TV was...
Your television has a USB port. Yyou can hook up your camera to the tv using a USB cable, goto input ->USB select pictures as the type of content to browse the pictures on the tv.
Jul 15, 2011 | Toshiba Televison & Video
There's a wire hanging down in back of the filter. don't know where it hooks to but think it has something to do with the temp. temp staying at 73 degrees. wire has yellow tip and look like it hook...
Hello, this is your temp sensor wire that leads to your thermostat. It engages and turns off the compressor, it should be mounted with a plastic mounting holder right on the evaporator coil behind the filter.
May 30, 2011 | Heating & Cooling
Where do i hook the blue wire up to on a dual xhdr6435 into the dash
Hi, the blue wire is used to turn on a separate amplifier or to raise the antenna. If you don't have a telescoping antenna or amplifier, just tape off the blue wire and leave it hanging behind the head unit. Please let me know if you have more questions, and thanks for using FixYa.
May 06, 2011 | Dual XDM6825 CD/MP3/WMA Player
Playstation 3 is on however the tv screen is
Since I don't know if this has worked for you before I can only give you advice. I'll do my very best to help you in whatever way I can.
If it's a new system I need to know how you have it hooked up. I'll start by having you troubleshoot some things:
If you want it hooked up through HDMI connection you'll need to hook up both the composite (Red White & Yellow) cord that came with it; along with the HDMI cord.
Turn your console on and set your TV input to whichever input the composite cable is hooked into.
Assuming you have picture:
Go to your settings and select Display Options. At the next menu, you'll want to switch it from composite to HDMI. Your screen will go blank.
Set your TV to whichever HDMI input you have it hooked to and you should see a display. Confirm if necessary.
If you still have no picutre:
What I would initially do then is make sure the system is off, turn your TV input to the correct video settings for the composite, and when you turn it on, hold your finger on the power button for a few seconds after it's on to set the default picture display.
You should have a picture now. If not, it could be your TV. Try these same steps on another TV.
Please let us know if you're having further issues & Good Luck!
Respectfully,
Don
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Ook Picture Hanger Shield" Logo
1,050 people viewed this question
Top Ook Home Experts
Donni Steen
Tom Chichester
Are you an Ook Home Expert? Answer questions, earn points and help others
