Question about Symantec Norton Antivirus 2009 1-User - Windows for PC
Why would presure be building in the fuel tank
I was driving the can when it shut off .When u slow down to stop the car stops running
You have--- No Vehicle shown---
WHY?
It could be an Evap System problem,
the pressure issue- that is, doubt it would
shut off,that may be another problem
What now?
I wouldn't use it & get stuck somewhere
Why the fuel tank pressure question?
Were can not even guess anymore for lack of info
Look at scan tool data & then diagnose any codes
& component test, to find a problem
That basically is the response to 80% of all these questions
Posted on Nov 25, 2014
RE LK 3504 (35 hp 4 wheel drive Tractor starts, runs 5=10 minutes under load, then slowly fades away running slower and slower until it stops. Restarts in 15 min, same result
Here is an idea.
It sort of sounds like there is a blockage after a while in the gas tank.
If there were sediment in the bottom of the gas tank, it would start and run fine sitting still.
However, when driving it, it would be a matter of a few minutes until the sloshing of the fuel would cause the sediment to mix in with the fuel, and clog the filter screen in the fuel tank.
When it stops, the sediment would settle back down, and in 15 - 20 minutes, it would be clear again.
God bless your efforts.
May 08, 2017 | Cars & Trucks
If I let a F150 run out of gas does the fuel pump continue to run?
Most original fit EFI in tank fuel pumps are designed to shut down when the engine stops running with the ignition switched on. This is a safety system eg inthe event of a frontal collision which disables the engine and a fuel line is severed the fuel pump should shut off. Its considered not a good idea to run out of fuel as this can cause internal damage to the fuel pump also poss cause the fuel filter to be contaminated. Is this a siutable answer?
Nov 28, 2014 | Cars & Trucks
Hard to refill gas tank have to pump real slow car runs fine
You've got your gas tank presure release valve.stuck or no good
Jul 15, 2014 | Hyundai Motor 2003 Sonata
I have a 2001 ford f250 superduty with the 7.3. It has a 6 position chip and is strait piped but no other mods. when i slow down to a stop wile driveing the check engine light comes on and tge truck runs...
i have had this problem its the emissions i sorted it out with a fuel additive in a tank full of fuel every 4k add the aditive you will find it will clean out your emmissions and stop the smoking plus give you better performance and better fuel economy, its a build up of engine deposits thats past to your exhurst the additive gets rid of the deposits as a gas, try cataclean this cleans your engine and converter or STP is another good one.
May 04, 2014 | Cars & Trucks
Can my muffler make my car run slower and shake?
CLOGGED FUEL FILTER OR WEAK FUEL PUMP CAUSE CAR TO HAVE LACK OF POWER AND SURGE.CHANGE FUEL FILTER,CLEAN FUEL INJECTORS WITH CAN SEAFOAM BY ADDING TO 3/4 TO FULL TANK OF GAS.CHECK FUEL PRESSURE SHOULD BE 41 - 47 PSI FOR 2.0L OR 3.1L ENGINES AND 9 - 13 PSI 2.2L TBI INJECTION SYSTEM.IF FUEL PRESSURE GOOD CHECK TRANSMISSION FLUID LEVEL.FAULTY TORQUE CONVERTER WILL CAUSE LACK OF POWER AND ENGINE SURGE.A STOPPED UP MUFFLER OR CATALYTIC CONVERTER WILL TAKE SLOW CAR DOWN MAKE IT SPEED UP SLOW DOWN SPEED UP SLOW DOWN.
Mar 05, 2011 | 1992 Chevrolet Cavalier
My toyota camry 94 starts but than shuts down by its self also last time i went to put gas and i removed the gas cap alot of presure escaped by there
every fuel tank has a ven't it shoulden't build up too much presure, the vent tube might me full of dirt
Jun 04, 2010 | 1995 Toyota Camry
My car stopped running after I refueled. What might be wrong
maybe water in your tank if the station was getting fuel in their tanks
Jan 08, 2010 | 2002 Ford Explorer
2006 Town and Country, While driving the warning lights came on (air bag, oil presure, low fuel, check engine, etc...) Speedometer stopped working, fule gauge went to Empty (had just filled the tank 11...
1)check the ignition switch is not loose.those things normally come on before starting.unless2) you have a main ground broken somewhere.rodents eat the wiring harness to build a nest and cause mayhem...i have seen that a few times .check the fusebox under the hood on the drivers side
Jul 04, 2009 | 2005 Chrysler Town & Country
Symantec Norton Antivirus 2009 1-User - Windows for PC  Logo
50 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
