Question about Garden
My troy built squall 210 snow blower will not start
I replaced the gas and spark plug
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Was the gas in there from last season? If it was... you better drop the bowl on the carburetor and clean the mess that the Ethanol Gas created. Ethanol Gas the Carb Kil ler
Posted on Nov 25, 2014
4 Suggested Answers
  • 30 Answers
SOURCE: Gas leaks from carb air intake on snow blower?
You might have a sticking needle valve
Posted on Jan 02, 2013
SOURCE: How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Posted on Feb 09, 2014
mark24354
  • 776 Answers
SOURCE: Need to find correct spark plug for Troy-Bilt
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Posted on Nov 16, 2014
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Craftsman Gas Blower Model 358.794776
No spark is the plug or coil. Check with a spark plug tester.
Oct 09, 2015 | Garden
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Ohv 179cc snowblower engine will not start
I'd check to make sure any fuel shut off valve (often "inline" or located directly under the tank) is open or on. Check or replace any inline fuel filter as well. If your snowblower has a priming bulb, you should hear gasoline spritzing after the second or third full press. More presses will probably cause gas to drip out of the carb to the ground. Next, check the spark plug. Clean or optionally replace it - set / check proper gap. With the plug out (and the spark plug wire away from the spark plug's threaded opening in the engine) pull the starting cord several times, and then check for the smell of gasoline in the cylinder. If no gas odor, you may have a bad float in the carb or other blockage. It will not run until you can get fuel into the cylinder. You can try pouring a few drops of gas into the cylinder of the engine via the spark plug opening or give it a "quick blast" of aerosol starting fluid or ether. Reinstall the spark plug and try again. If you added fuel, starting fluid or ether, the engine should have either attempted to run or sputtered briefly or is actually running. If it did neither, check for spark. Remove the spark plug wire from the spark plug and insert the tip of a screwdriver into the boot on the end of the spark plug wire and position the screwdriver's shaft to within 1/4" of the top of the spark plug. Be sure to only hold the screwdriver by the insulated handle (do not come in contact with the metal shaft of the screw driver) and pull the starting cord again. You should see a spark jump to the spark plug. If none, you may have a bad spark plug wire or magneto - and need to clean or replace it. before trying again. Good luck!
Feb 02, 2014 | Yard Machines 31A-62BD700 179cc OHV...
Snow blower runs rough, backfires
Clean the choke asembly and air filter .
Dec 26, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Sequall 2100 will not start
Change the coil at the magneto that generates the high voltage to the spark plug
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy bilt sequall 2100 will not start. has new plug
Is the gas making it TO the new plug? Pull it over a dozen or so times on full choke and then pull the uh to see if its wet meaning the engine is getting fuel. Also make sure the safeties and off switches aren't preventing it from starting
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
