Question about Building Materials
My door opener stoped model 13953910 D i checked capcitor and it is fine. what compatiable model can i replace it with.i don't want to replace track.
What is easiest replacement opener
    Problem Solver:
  • 13 Answers
I would go shopping for a garage door open or you are familiar with the hardware of your garage door look for a garage door opener system that uses similar or the same harbor usually the electronic remote the drive and the connectors are proprietor the track in the chain in the hinges and all of that are usually quite similar.
Posted on Nov 26, 2014
Interior lite and doorajar lite don't work when passenger door is not closed
a faulty wire on door check your fuses and replace them for the doors
Jan 14, 2013 | Cars & Trucks
Roper dryer wont start, do it have a reset button
Check the door switch. With the door open, press the button in and the light should go off. If you don't have a light, listen for a click form the switch as you push and release it. If you don't hear a click, you will need to replace the switch. If the switch is good, then problem will be with the thermal fuse located on the rear of the unit.
Sep 28, 2012 | Dryers
Driver side door removal of 1997 lexus es 300
Gently don't force anything. 1st check for any visible screws on door trim & undo. remove window winder if not power window you can buy a tool for this. carfully pull the trim out from the bottom of the door & work up. You will probably find it stops near the door handle. There is probably hidden screws behind the inner door handle trim & don't forget arm rests. just be gentle & yu should work it out & not brake anything
Jun 25, 2012 | 1997 Lexus ES 300
Power light no bot it is dade
it sounds like the Power supply board.
I'd check the fuse, check A/C voltage, D/C voltage....BUT
most likely it's the capcitor or resistor.
check for bulging capacitors and if u don't see any test the resistors.
Jan 07, 2012 | Philips 26PFL5322 26 in. LCD TV/HD Combo
Chamberlain hd400 open force setting at max. Just installed. Will only open door with open force at max setting. Door appears to be balanced fine. No obstructions noticed.
If you release the opener from the door and operate the door by hand it should be obvious if there is a door problem. If it is in warranty you can call Chamberlains technical support line at 800-528-5880. Double check that model number before you call. They don't recognize it.
Oct 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
1994 Saab Areo 9000 power locks will not work therefore cannot open gas door. Tried changing fuse but that didn't work
Check fuse #15 if you have not done so & check in the trunk for a manual over ride under the tool kit. The 90-92 models had one, not sure if your model does. I don't have a lot of info on the 94 A 9000-- Maybe a Saab expert will chime in with more advise.
Sep 24, 2011 | 1994 Saab 9000
Compressor run 10 min then stoped with VSD Fault39,or 40. I can reset, but the compressor run only after 30-45 min. He run another 10 min,then stoped again
OK I am guessing this is a modular drive. Fault 39 is an IGBT fault on phase U and 40 is an IGBT fault on phase V. Unless you are experienced it's best to have a qualified service tech do the repair. However here are my thoughts. The IGBT fault may be caused by a dirty air filter located in the side panel. It's some where around 10" x 12". If the electrical panel filter is dirty you don't get enough cooling. The IGBT's get hot and over temp. causing the above fault codes. Check the filter and replace if needed. Next in top of the electrical and drive compartment is a fan. Make sure it is operating properly. If the fan is not operating again you get no cooling air for the IGBT's. I have seen customers open the panel doors and put a large fan blowing on the drive to cool it. I don't recommend this due to the fact the air is unfiltered and can get dirt into the drive and cause damage!. However some customers have to run and take the chance. There are also other items that can cause these faults. But as I said before determining whats wrong can be very technical. Does the display show any other # after fault 39 or 40 like 39 - 3 or 40 - 2. If so this gives additional info on the fault and tests to perform like checking the ID board or interface board. Good luck hope it's a filter.
Sep 08, 2011 | Ingersoll Air Tools & Compressors
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
Aug 24, 2011 | 2004 Pontiac Montana
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Building Materials Logo
51 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
