Question about Vacuums
Bypass bag full sensor - Vacuums
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Use a compressor to blow off the sensor clean entire area of filtrations etc..
Posted on Nov 26, 2014
Where is vacuum chamber on a Windsor sensor xp12
it comes up from the back,it is probably plugged or the sensor is dirty
Apr 21, 2015 | Windsor Vacuums
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
Stopped working, lights work, shows full light when not full.
Remove the bag and put in a fresh bag. Then rotate the dial on top of the vac to the middle position. When cleaning fine dust the vac will shut off before the bag is full as it is sensing a clogged bag and cannot sense proper air flow through the bag. If this persists the sensor under teh top dial may be damaged and need to be replaced
Sep 08, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Full Bag Shut-off Comes on With New Bag and No Hose
The control valve has gone bad. This is the dial that you move on the top of the vacuum that has little indents on it.
You cannot do anything to bypass this problem from outside the machine.
This is not a repair that you can make yourself. You should look in your local yellow pages for Aerus (new name for electrolux) under vacuum cleaners, or go to www.aerusonline.com and find your local dealer. It is not too expensive to have fixed, it is a common issue with later model electroux vacuums.
You can try a test to see if it the valve. Remove the bag from the vacuum, look at the back of the bag holder near the motor, in the upper right or left depending on your model. You will see a very small hole 1/16 or an inch or so. Put a piece of tape of some sort to close off the hole. Replace the bag, turn on the vacuum, if it is a bad valve, the tape will override the bag full action, and the vacuum will run.
It is not advisable to run the vacuum this way since it will overheat, damage the thermostat, and can destroy the motor. A motor will cost over $200.00, the valve can be replaced for a lot less….
Jul 29, 2009 | Electrolux Epic 6500 Vacuum
'Bag Full' light indicates at 1/3 bag
The sensor is a small hole into the vacuum chamber. It moves the alert system as vacuum inside the unit builds up.
The filtration, built into the bag, is getting filled up and creating a higher vacuum inside the unit, giving a false reading. The only ways to eliminate this are to give the bag a shake to clear some of the dirt out of the filter, try to pick up coarser dirt first or buy generic bags-without the filtration.
Jul 21, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Can't open my EPC 6500 Electrolux
What you do is open the bag cover, then lay the machine on its side. Wedge a flathead screwdriver in between the bumper and the rear plastic guide. With a mallet, strike the flathead towards the bag cover. (The front of the machine.) Until the guildes come off. After both sides are done, close the bag cover and roll the machine so it rests on its back. With 2 fingers inside of the opening where the cord comes out, pull up firmly with the other hand holding the machine in place. TA-DAH.
I wouldn't bypass the bag sensor if I were you. It's there for a reason. It sounds like your control valve is out. Change that and your problems are over. Quick and super simple fix.
Oct 18, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
