Question about Standard Motor Products 1994 - 1997 Chrysler LHS Turn Signal Flasher
Where is turn flasher located on a 1994 Chrysler lhs
    Sergeant:
  • 248 Answers
Although I don't have an answer for you, I can tell you that most flashers in older vehicles are round and have an aluminum housing, and they are about 1.25" and they are known to be separated from the fuses. some vehicles have it under the dash on the passenger side. if it is bad and does not blink and you can't hear it, you can try listening to it by manually working it with the engine off and ignition on. best luck to you.
Posted on Nov 25, 2014
    Novelist:
    Scholar:
  • 165 Answers
Http://www.manualowl.com/a/Chrysler/1994-LHS/Manual/1727
This is a link to the manual. If you can't find it in the car then you will need the manual.
Trying to locate turn signal flashers on 1999 LHS?
It Is A Combination Flasher And Is Located--Left Side Of Dash Between Junction Block (fuse panel) And Brake Pedal
Feb 26, 2015 | 1999 Chrysler LHS
2001 chrysler lhs flasher
It may be on top of the steering column. Hear is a link that might help.
https://www.youtube.com/watch?v=ikJHh7OLcXg
Mar 22, 2014 | 2001 Chrysler LHS - Sedan - Weathershield...
Do you know where i am suppose to replace the flasher fuse on a chrysler lhs 1999
The flasher is located under the drivers side dash... Look to the left of the steering column area. If you have purchased a replacement, then just look for a similar looking flasher. Best of Luck!
Aug 20, 2011 | 1999 Chrysler LHS
Where is the turn signal flasher located on a 1994 chrysler new yorker
Your flasher is located in the front seating area, driver side, under dash, under knee protector, mounted in multi-purpose fuse panel. I hope this helps you and good luck.
Apr 13, 2011 | 1994 Chrysler New Yorker
Turn signal and flashers not working
Replace Flasher Located 1 of 2 Places Fuse Box Turn ON HAZARDS and "FEEL for one to CLICK the One that DOES Is for Hazards Swap this one Out with the One that Does Not CLICK or under Dash Just to the Right of Drivers Side. They Are GREY in COLOD Made of ALUMINUM. Some Aftermarkets are BLACK PLASTIC.
Sep 22, 2010 | 2001 Chrysler LHS
Turn signals and 4 ways are completely out. Have replaced flasher, sterring column switch. Bulbs and fuses are good.
sounds like a hard wire problem. try moving the main harness around the fuse box to make sure theyre making contact.
Nov 14, 2009 | 1994 Chrysler LHS
Where is the fuel filter on a 94 chrysler lhs?
go under the car, It is located about 1/2 way up the right underside of the vehicle
Sep 17, 2009 | 1994 Chrysler LHS
In a 94' Chrysler LHS what is the firing order? Took the plug wires off the housing unit.
1994 Chrysler LHS
3.5 liter SOHC V-6 VIN "F"56539136.gifI HOPE THIS IS WHAT YOU NEED. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. FEEL FREE TO COMMENT ON THE ASSISTANCE
Sep 06, 2009 | 1994 Chrysler LHS
Turn signals in96 LHS chrysler won't work
did you replace flasher solenoid, see if the emergency flashers work all around vehicle, if not then replace bulb that does not flash
Jul 30, 2009 | 1995 Chrysler LHS
Standard Motor Products 1994 - 1997 Chrysler LHS Turn Signal Flasher Logo
76 people viewed this question
Top Standard Motor Products Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Standard Motor Products Audio Player and Recorder Expert? Answer questions, earn points and help others
