Question about LG Refrigerators
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
I turned it off for a couple of days i have taken everything out of the fridge i have just turned it back on and still beeping the fridge and freezer are working is there some way of making the beeeping stop thanks
    Novelist:
    Scholar:
  • 165 Answers
Http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Posted on Nov 25, 2014
catriver
  • 878 Answers
SOURCE: freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Posted on Sep 20, 2006
HVACRH20
  • 237 Answers
SOURCE: GE Fridge/Freezer Having to turn temp up just to keep it cold
That's a typical sign of the defrost cycle not working and ice is building up on the coils. That prevents proper air flow of cold air around the compartments. As ice builds up you get less air flow and things warm up soooo you turn up the cold which causes more ice to build up and even less air flow soooo you turn up the cold. See where I'm going with this? You'll have to check your defrost timer, defrost t-stat and even the heat element. Look in your owners manual or online for diagrams of where the parts are located on your older unit, then go from there.
Posted on Dec 30, 2006
Noggin
  • 944 Answers
SOURCE: AEG fridge/freezer isn't working
This sounds like your fridge has a leak somewhere and it slowly discharged its refrigerant. the compressor can sustain damage when there is no refrigerant and often will hum and eventually fail. Sorry but you may need a new compressor - if you were going to replace the fridge soon anyway then i would go ahead, but a compressor and the labour to fit it etc may be cheaper than a new fridge - you need a refrigeration repair man/shop (if you can take the fridge to a repair shop it will always be cheaper than calling a guy to your house) Sorry i can't really help, but the symptoms are classic, if you are lucky then a technician may be able to fix the leak and restart the compressor, but not always if you want to try something yourself just try tapping the compressor smartly but not too hard with the end of a dry wooden or plastic stick or similar with the fridge plugged in. the compressor is the thing at the bottom in the back that looks a bit like a small fuel tank, should be right in the middle and will be the largest thing in there. Just be careful not to break any copper tubes or touch any wires. Sometimes a stuck compressor can be freed this way, but you will almost certainly still need the leak fixing and a refill of refrigerant. Sorry about the bad news :( Hope this helps :)
Posted on Mar 09, 2007
eagle338
  • 4889 Answers
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Posted on Jun 13, 2008
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
My lg refrigerator just gave out. Its plugged in but its not working. I have checked the circuit brakers and everything is fine. Is this fixable or do i need a new fridge? I have owned this one 2 years
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge into another outlet and see what happens. A 2-year old fridge is almost brand new.
Jan 23, 2011 | LG LSC27910 (265 cu ft) Side by Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The computer makes a loud beeping sound 5 times
Mass storage device is a usb drive, flash memory etc.
If you disabled the usb device, it will no longer work, that is why you do not hear the beeping any more.
You need to get the correct device driver for your usb so it works correctly.
I hope this helps.
Good Luck.
Mar 13, 2009 | Computers & Internet
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Refrigerators Logo
896 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
