Question about Kitchen Appliances - Others
Mix and go blade stuck - Kitchen Appliances - Others
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
The mixing blade is stuck in the tin . How do we get it out?
Try soaking it over night or even for a couple of days. Put just enough water in it to cover the paddle completely plus about an inch with a little detergent. Whatever you do don't try to pry it loose with anything metal because you will damage the nonstick coating on the paddle and/or the breadpan!!!..............If it still won't come out log on to you tube and type in "How do you remove a stuck bread machine paddle" ......you will see my video of how to remove a seriously stuck bread paddle with no damage to your pan or paddle.
Oct 10, 2010 | Sanyo SBM-20 Bread Maker
We have a Tostmaster breadmaker TBR15. Looking for a new blade.
check the service section in your manaul. If you don´t have one, ask the manualfox search engine team, they will find you any breadmaker manual:
http://manualfox.com/searchengine/breadmaker.htm
Apr 05, 2010 | Toastmaster TBR15 Bread Maker
Mixing paddle won't turn.
The mixing paddle is supposed to turn by means of a lubricated bearing. This bearing is broken or stuck so the blade will not turn.
Try soaking it overnight in soapy water. If that does not work it's time for a replacement pan if you can find one.
Hank
Oct 04, 2009 | Sunbeam 5833 ExpressBake Bread Maker
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
Mixing blade
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Dec 08, 2008 | Betty Crocker BCF1690 Bread Maker
While mixing pie crust is the blade to be removed from the bowl or to remain inside? This is the first time I'm attempting to mix pie crust in my food processor and I have misplaced my manual. Many Thanks
you need the blade in the unit in order to mix the pie crust. but do not over mix. its best to do it in short pulse bursts. otherwise the crust will come out resembling fluffy playdough and will not holdtogether during baking
Nov 25, 2008 | Hamilton Beach Big Mouth 70590 Food...
Kitchen Appliances - Others Logo
97 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
