Question about Garden
Ok so the problem,on my gravely zt 2250 is was mowing went to shut blades off and they kept on spinning and there also spinning when trying start engine replaced clutch twice still same problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Check the pto switchmake sure electric is shutting off
Posted on Nov 26, 2014
  • 1,169 Answers
Sound like either the PTO relay is struck in run position or the PTO switch has failed and applying 12v to the PTO relay even in the off position.
IPLs for the Gravely ZT2250
Wiring_Diagram/10265/10261
Posted on Nov 25, 2014
  • luis alicea Nov 25, 2014
    its a new pto switch and i swapped relays unless theres others i cant find
3 Suggested Answers
  • 3506 Answers
SOURCE: i replaced the electric clutch switch etc on the
It sounds like you have made an error in wiring it
Posted on Nov 24, 2014
  • 3506 Answers
SOURCE: its a gravely zt 2250 new electric pto switch and
If the blades are PTO activated then you have wired the pto incorrectly
Gravely zt 48hd starts, blades engage and start, but mower will not move forward or reverse after lowering brake. suggestions?
There should be a lever/engagement clutch on the back of the mower. It is disengaged when you manually push it. It will have to be engaged again to allow it to move.
Jun 24, 2016 | Garden
Its a gravely zt 2250 new electric pto switch and blades are engaged when trying start engine
Nov 24, 2014 | Garden
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engage blades engine shuts down
if you removed the seat and then placed a fuse in the plug for the saftey switch and then started having this issue . with my experience with the safty switches on the seats most are open as not connected to make a circut when your sitting on the seat or pressure is applied to the seat . try removing the fuse and attempting to start mowing or least ingauge the blades and that should fix your issue ... when removing the origonal seat you just left that curcut open so it can not close and make connection when you get off the seat . so you should be fine after removing the fuse from the socket .. happy mowing
Nov 07, 2011 | Craftsman Garden
How to change the clutch on a gravely ZTR 260z. What keeps the clutch from spinning around on the engine shaft? A diagram of the clutch assembly would help. Instruction on removing and reinstalling might...
There is an "anchor" that bolts to the chassis, and it has a rod-like part that sticks up to engage a notch in the PTO clutch to keep it from spinning. Look here -- there are parts diagrams for your mower (find the right model number) that will help a lot. Good luck!
Jul 07, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
