Question about Oreck Vacuums
How do I find out the bulb size in my Oreck xl 9100
Need to replace bulbs, but don't know what size they are
Have to take it out first
Then match it up on a web site,
that sells lamps
Hopefully it has number on it
Owners manual & a call to the company
will get your the answer
Posted on Nov 25, 2014
b0sslady2001
  • 357 Answers
SOURCE: Oreck XL Vacuum
If you can find a Kirby G series vacuum lightbulb, it will work in the Oreck too!! Many sellers carry them online.
Posted on Apr 21, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 20 Answers
SOURCE: Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Posted on Mar 27, 2009
  • 206 Answers
SOURCE: oreck xl 9100 bag wont stay on
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Posted on Jul 30, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
Do you have wirirng schematic?
this is from a previous fixya answer but is works for the 9100 I rewired my 9100 motor connections like this and now does not blow out the lights and work great
Aug 30, 2014 | Oreck Vacuums
Schematic for xl 9100
A quick three second google search turned up
http://www.vacpartswarehouse.com/Oreck-XL9100HG-s/2927.htm Vac Parts Warehouse
Jan 24, 2014 | Oreck XL21 Bagged Upright Vacuum
I have a Oreck XL 9100 and need a manuel
Go to www.oreck.com and order one directly from Oreck.
Aug 09, 2013 | Oreck Vacuums
I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 9100 bag wont stay on using type cc replaced inside bag hanger
What year model?
Jul 22, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Vacuum
Apr 21, 2008 | Vacuums
Vacuums Logo
64 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
