Question about Banks 2003 GMC Sierra - Extended cab, short bed, 6.6L Duramax, without catalytic converter - Big Hoss Bundle
What causes a reduced engine power code.
The truck is a 2003 sierra slt 4.8 vortec. when driving a reduced engine power code will pop onto the dashboard reader and it is lacking power. when you shut the truck off for at least a minute and start the truck again the truck works fine.
You need to stop using any vehicle, with any
problems,lack of power & system faults & dash
MIL lamps lite
A repair shop or dealer, will answer that, after
they check for codes & diagnose the vehicle
to find a problem
Posted on Nov 24, 2014
Where is the throtle actuator control for 2003 gmc sierra 2500 hd?
If this is "fly by wire" throttle, any misalignment between gas pedal and TPS will cause this issue. Failure of the gas pedal sender is so common Lokar company makes a replacement pedal unit that is much better than stock.
Apr 24, 2015 | 2003 GMC Sierra 2500HD
What causes a 2004 gmc searra to have Reduced engine power come up
You may want to have your catallitic converter checked
Apr 10, 2013 | 2004 GMC Sierra
Dash light says--Reduced Engine Power
You need to have an OBII scan(fault scan) - to identify what sensor triggered computer (light) Reduced Engine Power = rig is in "Limp" mode. So you can drive it to get to repair shop.
Mar 12, 2011 | 2003 GMC Sierra 1500
Where is the Reduced Engine POwer Sensor Located
That is not what you are looking for. The issue is a decision by your engine management computer, based on some failure. What needs to happen is you pull the codes from the computer, requires a scanner, and proceed on the error codes.
Often a lube shop or parts store will pull the codes for free.
The issue is fairly significant if the systems reduced power. Pull the codes and begin there.
Dec 31, 2010 | 2003 GMC Sierra 1500
SERVICE AIR BAG LIGHT STAYS ON AND REDUCED ENGINE
It will be more help full if you can provide the trouble codes.
Nov 12, 2010 | 2003 GMC Sierra
The engine light comes on and a message saying engine power reduced. have to turn off ignition and restart truck. getting really bad.
Your going to have to get the Sierra scanned for the DTC code to why it's setting the ECM to reduce the power. Auto Zone or Parts Source will scan free of charge so you can address the issue. There are a few things that will set the reduce engine power like a faulty throttle peddle position ECT. Keep me posted, be glad to help you get your Sierra running 100% again soon.
Feb 22, 2010 | 2003 Chevrolet Silverado 2500HD
Service engine soon and reduced engine power
disconnect batt. for 30 min. then reconnect,if no problem exist the lights will go away
Dec 20, 2009 | 2003 GMC Envoy
I need the firing order for a 2003 vortec v6 engine GMC Sierra trucck
1-6-4-5-3-2
clockwise rotation
front - 2-4-6
rear 1-3-5
good luck!
Sep 01, 2009 | 2003 GMC Sierra
2003 GMC Sierra 1500 looses power at highway speeds, however the engine sounds normal
Does the reduced engine power message come on? if it does check the electric connector at the throttle body. sometimes the wires get dirty or something. and usually the yellow one.
Apr 10, 2009 | 2003 GMC Sierra 1500
Banks 2003 GMC Sierra - Extended cab, short bed, 6.6L Duramax, without catalytic converter - Big Hoss Bundle Logo
80 people viewed this question
Top Banks Computers & Internet Experts
David Payne
David Payne
Are you a Banks Computer and Internet Expert? Answer questions, earn points and help others
