Question about Rheem Water Heaters
Just moved into a mobile with a Rheem 72- 40- 1 water heater. The piping on the side looks good, but there is an opening in the top that looks like it is supposed to have a pipe. It is wet. Is the uni
Just moved into a mobile with a Rheem 72- 40- 1 water heater. The piping on the side looks good, but there is an opening in the top that looks like it is supposed to have a pipe. It is wet. Is the unit broken?
    Top Expert:
  • Rheem Master
  • 22,085 Answers
Probably not but I think it should have an outlet breather pipe.
Posted on Nov 24, 2014
gary1121
  • 332 Answers
SOURCE: Rheem 25 ltr cylinder leaking from top
if it is comming out of the cover , you will need to replace the unit ther is no way to fix the tank,, is it comming out of both the inlet and outlet, if it is just comming out of one wipe it of and look at the threads it could just be the adapter in which case you need to drain it and cut the pipe remove the adapter put teflon tape with pipe thread sealer. put the adapter back on, re attach the pipe, if it still leaks you will have to change the unit, if it is electric make sure you turn it off at the circuit breaker before draining you don;t have to drain it all the way
Posted on Jun 06, 2009
  • 6 Answers
SOURCE: Can I Use Existing Venting from Old Water Heater?
Late answer to an old post, but no you can't use the existing vent pipe. The tankless systems require Category III vents along with all the accessories required for your installation. I suggest you use a direct vent model with the concentric vent through the wall. Remove and patch the roof penetrations of the old vent or just abandon and let it remain.
Posted on Jun 10, 2009
  • 12104 Answers
SOURCE: it's leaking slowly from the top
if the line feels cold its the fill line if warm its the hot line either line try to tighten the connection if no good or leak is from solder or connection if u have valves to and out shut them off or turn off main open a faucet relieve pressure at heater either solder the line to repair or if connection Teflon tape joint and retighten connection good luck and thanks for using fixya
Posted on Oct 10, 2009
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
  • 2976 Answers
SOURCE: I have a Rheem 81v52dt 50 Gal Elec heater. Water
If you mean the safety valve, replace it. They're only a few dollars.
Posted on Jun 21, 2010
Reliance 501 electric water heater
Reliance-Rheem may have changed away from generic parts so you have to buy special order parts from them.
I have not heard of this before for elements... but Rheem does that for other parts.
Avoid Rheem products.
Rheem also makes a 1-3/4" element to fit Marathon water heaters, instead of standard 1-1/2"
Actual thread size for standard water heater is same as 1" pipe, except straight thread instead tapered pipe thread.
See if 1" pipe will thread into water heater element opening.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene Haynes
Feb 15, 2014 | Water Heaters
Hot water heater sweeting from top
Water on top of gas heater can be caused by poor venting, or inadequate combustion.
Make sure water is not coming up from under tank top, indicating tank leak requiring tank replacement.
Have a plumber look at problem to make sure home is not filling with deadly, odorless CO gas.
Inspect pipes that they are not corroded and covered with condensate.
Check that roof cap is in place.
Let heater fire and burn for a few moments so the fire is going good, and then light match just outside the draft hood on top of heater. Blow out match and see if smoke draws immediately into vent and upward.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Leaking-water-heater.html
Aug 31, 2012 | RHEEM 50 Gallon FVR NATGAS Water Heater...
I have a rheem heater M/N 81V40D how do I change the anode?
Unless you see a large hex head socket to remove on the top of the water heater, many
anode rods are built onto the hot side nipple. They are almost the length of the water heater.
Hopefully you have room to remove it if this is the case. If you see a hex nut that is silver
gray on top, then shut off cold water to the heater. Release some hot water at a tap to relieve
pressure on the tank or drain some out at the bottom which is better. Make sure power is
off to unit first or gas is off . Unscrew nut or nipple counterclockwise to remove. Best to
remove with a socket wrench or box wrench if it's a nut and a good pipe wrench if it's
on the nipple. Several light taps with a hammer if necessary on the handle of the
wrench or pipe wrench should help. Hopefully the nipple has a removable flex line if
it's located there. (Remember it's on the hot side and should be marked on the top
of the heater).
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am losing water pressure, but only on the hot side. Cold pressure is fine, as you add hot the pressure fades, the hotter the less pressure. This is at all points in the house. The water heater was...
You have a clog in the hot water line.
If problem is at one faucet, then remove aerator and clean, then disassemble lines underneath sink.
If problem is at every faucet, then that moves search close to water heater.
Look at hot water line that exits water heater and trace that line to first Tee.
Look at cold water line that enters water heater and trace that line to Tee.
Clog is located between those 2 Tees.
Buy pressure tester that connects to hose thread.
Connect pressure gauge to hot water heater drain valve.
Then conduct same test you did at faucet.
See if pressure drops at tank.
If pressure drops, then clog is on cold side of tank, and probably hot side too.
If pressure does not drop, then clog is on hot side of tank.
Suspect 1 is any place two different metals join. For example galvanized pipe and copper.
Suspect 2 is supply pipes that exit top of tank. Take apart and look inside pipes for corrosion and sediment lining pipe walls.
Suspect 3 is elbow. Disassemble pipes and look for sediment and flakes of rust.
Suspect 4 is all suspects above, each having sediment and corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 19, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater will not heat water
There are a lot of causes.
First step at fixya, you say what type of water heater you have.
Gas tank , Electric tank, Tankless.
If you do not know, then look at unit.
Gas tank is about 2 feet in diameter and stands 4 to 5 feet tall. It has 2 water pipes on top, a 4" diameter galvanized pipe sticking out of top
Electric tank is same size, it has 2 water pipes on top, and a wire sticking out of top.
Tankless is a box that is attached to wall.
Look for label on side of water heater.
Write down all the information shown on label, and add a comment with that information.'
And then say what symptoms you noticed prior to water heater failure.
For a price, fixya expert speaks with you over phone while you work on water heater.
We are less expensive than a service call, and we have satisfaction guarantee.
Jan 14, 2011 | Rheem Water Heaters
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
For a price, fixya expert speaks with you over phone while you work on pipes.
Jan 05, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
It's leaking slowly from the top It's a Rheem 82v52-2 water heater and we came home and there was a puddle of water in the floor. It's a slow and steady leak. It starts at the top on the right side. I...
Oct 10, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
51 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
