Question about Master Equipment Z-Lift 42 by 24-Inch Hydraulic Table Ivory
Having a problem with garage door not opening from car--it used to work every time and now it only works part of the time.
I can open and shut door from wall unit. My third car works fine with the remote.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Check the battery, even if you have replaced it lately. The contacts in the remote might be worn, unless you have an a solid state remote. Check the code in the garage and in the remote, make sure they are the same
Posted on Nov 24, 2014
Ok so I am having a problem with craftsman garage door, The sensor light are right on green and one orange, but i still have to hold down the button in the garage to shut the door. Also today i thought...
If when you try to close the door the main light flashes 10 times and the door starts down and then reverses to the open position you have a door sensor problem. Make sure the lights in the sensors are not flickering ever so slightly. The color of the lights doesn't mean anything. The keypad sounds like a separate problem. Make sure the battery is good.
Apr 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Model 139.53515SR overhead lights stopped working. Checked bulbs and all connections. All seems O K. What could be the problem? When I tap the unit ,at times the lights will flicker like...
Unplug the openers and remove the bulbs. Using a small screwdriver pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
We're having trouble with the remotes will open the door but will not shut it. Tried recoding but did not work. What next?
If the main light flashes 10 times when you try to close the door it is a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you can't get both lights to come on you have bad sensors.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My reddy heater 125t starts fine but only runs for a couple of minutes and then shuts itself off and the red lights that says flames begins blinking. but we open the garage door about a foot and it works...
Read your manual....it will explain why and what happens when not done.Your machine ( which I have ) requires a 11" opening of fresh air in a garage. I use a fan sideways behind the machine and that seems to work without having to open the door, also helps circulate the heat at the ceiling.
Dec 29, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to program the homelink garage door opener on my 2000 navigattor
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Mar 10, 2009 | 2000 Lincoln Navigator
Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Aug 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Liftmaster garage opener model #114OLM
when you are programming , how long do you push LEARN button for, If you push for 6 or more seconds, you are wiping out all code, Push for 1 second to add a remote or keypad,
Jan 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Master Equipment Z-Lift 42 by 24-Inch Hydraulic Table Ivory Logo
Top Master Equipment Science & Laboratory Experts
William McMath
ray gallant
Are you a Master Equipment Science and Laboratory Expert? Answer questions, earn points and help others
