Question about Nikon 50mm f/1.8 AF Nikkor Lens
My 50mm nikon lens rear cap will not remove! i tried turning it clockwise (its supposed to to unscrew) and couldnt losen it, i even had my PT friend to try unscrew it but no luck. HELP!
Being all excited first time using a dslr, when i was packing everything i just screwed on the cap without looking that it needed to connect and align with the white dot, but I've asked a friend who has the similar lens and he said even screwing it without aligning it you can still unscrew it as long as when you are unscrewing it, your turning it clockwise. If i look at the cap it looks like its evenly screwed. im not a strong person so i dont know how i could have tightened it so tight.
  • 169 Answers
Your right if put on correctly, It should just unsrew clockwise,
Posted on Nov 25, 2014
3 Suggested Answers
  • 13 Answers
SOURCE: Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Posted on Jun 12, 2009
  • 146 Answers
SOURCE: Nikon 50mm 1.8 lens error message
The 50mm lens is fairly old and uses a different system to the later lenses. On the D90 and other later cameras you should rotate the ring to 22 and lock it there using the lock just above the aperture ring.
To adjust the aperture you use the front dial by the on/of switch.
Try it out in A mode. Rotate the mode dial on the top left of the camera to A (Aperture Priority mode) then lightly press the shutter button to turn the meter on. Then rotate the front dial and you will see the aperture reading changing.
The older Nikons changed their apertures using the ring but the later Nikons use the camera controls.
Posted on Jul 03, 2009
How do I remove stuck rear lens cap for telephoto lens on D3200
Are you sure you're turning it in the proper direction? Nikon lenses (and thus rear lens caps) screw in the "wrong" way. The lens cap turns clockwise to remove.
If it's an ordinary plastic lens cap, as a last resort you could cut it open with a knife.
Feb 01, 2015 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Remove stuck rear lens cap
The first thing I would try is using one of those rubber pads that are used for removing stubborn lids from jars. If that dose not work, I would use the fact that the Nikon rear lens caps are made out of soft plastic to my advantage. If you have a Dremel rotary tool with a disk cutting tool, you may be able to CAREFULLY and slowly cut away the lens cap. You didn't say which lens this is, but since with most lenses the telephoto position moves the rear element away from the back of the lens, I would set the lens to telephoto before starting to cut. I would start by cutting through the back of the lens cap. Cut a little at a time and try to take off the cap. Proceed slowly periodically trying to remove the cap. Hopefully, the pressure will be relieved and the cap will release before it becomes necessary to cut across the lens flange. When you are done, I would carefully clear the lens of any debris.
Jul 05, 2014 | Nikon Cameras
How to remove stucked lens cap
It depends what lens cap you have some lens caps you pinch off
Others you pull off some screw off its the easiest thing you can do on the camera you should have had a a1 filter screwed on before the lens cap then all you would have done is unscrew it all.
Then again you may have to take it to Nikon on Wilshire
Jun 08, 2014 | Nikon D3100 Digital Camera
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
I am trying to mount the AF f/1.8D 50mm lense on my Nikon D90- I do not here the click sound - when I turn on the camera, in the view finder I see F-- flashing all the time in any mode. Can you help me...
This particular lens is known to be a tight fit, especially when new. Most likely you just need to turn the lens a hair more and a little bit harder than you normally would in order to have it "click" home.
Dec 18, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
We have a nikon 50mm 1.4 nikkor lens that when
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Oct 23, 2009 | Nikon Normal AF Nikkor 50mm f/1.4D...
I need a Nikon CS-11 soft camera case for my Nikkormat EL 1972. Where to find please? Also a lens cap for the f=50mm 1.4 lens please. BR Gerald Kingsbury
Try ebay. Search on Nikon CS-11 .
They don't any now but keep trying. Two were listed for $5.99 last month with no takers.
Sep 12, 2009 | Photography
Stuck lens adapter
Aug 07, 2009 | Nikon 50mm f/1.8 AF Nikkor Lens
Jun 25, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon 50mm f/1.8 AF Nikkor Lens Logo
59 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
