My vtech handsets say line in use...the intercom buttton is on and the red light aove charge is lite. how do i turn off the intercom it was pressed in error and i have been without a phone for the pa
I READ THE MANUAL AND NOTHING WORKED
Try the factory reset initialization. Put the set back to factory settings. Sounds like the power on and timer are set together. I had one of these and needed to reset to fix the problem. The procedure is in the back of the manual.
Posted on Nov 26, 2014
How do I register a cs6114 phone
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
Nov 17, 2014 | Vtech 5.8GHz Analog Cordless Phone
VTech CS6409 register handset fails with no message
From what I read it seems you are trying to register and add a new handset to your system. I am also assuming that the handset is de-registered.
A common problem with registering a handset to this system is Owners Press and Hold the # sign before releasing it. This button is to Press and IMMEDIATELY release. DO NOT HOLD. If this does not solve your problem then
With a charged battery in the handset, the display should read "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" if it say so, then when you press and "IMMEDIATELY RELEASE " the # sign on the handset the information should change If the screen goes blank when you do so and return to "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" then you will have a bad battery or your base memory is full.
Replace the battery and try again. If no change then
The best way to go is to clear the system and re-register all the handsets. Begin by removing any handset from the main base cradle. Then
Press and hold /FIND HANDSET on the Main base until the IN USE light turns on and starts to flash. then release it, then without pause Press and Release it again. That will clear the system and de-register all your handsets.
All handsets will show 1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET. To re-register follow this instruction
Jun 02, 2017 | Vtech Lands Phones
How to use the intercom
Press the INT button then the number of the handset to call.
See page 15 of this manual.
Apr 02, 2013 | Vtech Cordless 6041 Phone
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
Can i call from one handset to the other
The model number listed is for a single-handset cordless phone, and the manual only shows a "locate" function from the base. It's handy when you misplace the handset, but it's not an intercom feature. You probably have a different model since you ask about calling between handsets. Some systems do provide this ability, but without your actual model number I can't give a definite answer or link to the manual for instructions. Here is VTech's manuals page, where you can find your specific model. The manual will explain how to use the intercom feature if it's available.
Jan 30, 2011 | Vtech IA5854 5.8 GHz Cordless Phone
Can you tell me how to get out of SP-PHONE which has a red light
Under my Intercom light I have a green light (7731,7735). I'm not sure why yours is red, but here are a couple of things to try.
Press "1" on the keypad without picking up the handset. That turns off Background music and the display will say BGM On or Off.
Press Intercom or pick up the handset and dial 790. That's the extension reset code.
If neither one of these work, post back with the model number of the phone system cabinet the phones are plugged into. It's probably a Panasonic TA-624/824 but there's a chance yours is different.
Carl
Mar 02, 2009 | Panasonic KX-T7730 Corded Phone
How to connect additional unit to base unit special code ?
Hello. Here is how you do register your handset below, and a link to the manual its on page 46. The procedure depends on how many handsets you have. If you only had one handset follow the directions below. If you have more than one handset follow the second set.
On the handset push menu, then dial 0 0
On the base, push and hold down the locator/intercom button until the charge light flashes
Press OK on the handset, and it should automatically register in a few seconds.
On the base, press select until you see the intercom number you wish to register it to. Stop there and push the Call button until the charge light flashes
Push OK on the handset, and it should register
Hope this helps
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Feb 28, 2009 | Panasonic KX-TG5632 Phone
2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Sep 26, 2007 | GE 2-9450C Corded Phone
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
