Question about Hyundai 2011 - Accent
How do I find the manual transmission fill area on 2011 Hyundai Accent
Looking but not finding anything remotely like a dipstick
    Problem Solver:
  • 16 Answers
Go to a auto part store and ask them to show where if at they canpull it up on the computers it might have a closed transmission on it where you have to go to dealer or someone who knows about them type transmission
Posted on Nov 25, 2014
Without buying the required service manuals & today
they are mostly on CD, you just have to recognize what
your seeing under the vehicle
I can only suggest You Tube Video
I find almost all these questions for folks on there,
when for some reason, they can't
I know your last thought would be to stop at a trans shop, because people hate the automotive industry, but they would tell you
May even have a trans out on the bench to show you
Not many dip sticks left
Not ones you remember, but they are there they just are
under a bolt or cap or part of it
Most owners manuals or some should possibly tell you
Posted on Nov 24, 2014
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Entire car and steering wheel wobble on my 09' Chevy Cobalt when driving straight. There is no difference when turning left or right. What is it?
Have you checked the steering wheel linkage ?
2009 Chevrolet Cobalt. Consumer writes in regards to steering column problems. The consumer stated part of the steering column was replaced 4 times, since the vehicle was purchased new in 2009. The problem was originally noticed as a rattle in the dashboard area in December 2009. The steering column was replaced. A similar noise returned in October 2010, where the steering rack and pinion input bearing was replaced, and on March 30, 2011, the steering column was replaced again. In February 2014, the rattle returned for the 4th time and the steering column was replaced. On November 2, 2011 the consumer attempted to turn off the vehicle, but was unable to do so. The dealer replaced the ignition switch. The old switch had completely apart inside the steering column.
see attached link for more
See attached link for more
Jun 01, 2014 | EBC Brakes 2009 Chevy Cobalt - 2.2L 4-cyl....
Where is the pcm/vcm location on 1999 chevy tahoe?
Shift the vehicle's transmission into park (automatic) or first gear (manual transmission). Turn off the engine, then rotate the ignition back to the "ON" position, but do not start the engine.
Connect the scan tool's data communication cable to the vehicle's diagnostic data port underneath the dashboard, above the foot well area.
LET ME KNOW THIS HELPS
Sep 17, 2012 | AM Auto Parts 1999 Chevy Tahoe 5.7L...
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
None of the buttons operate and no light
It would appear that the machine is not receiving power for some reason.
1) Check the plug in the back. Make sure it is inserted firmly! Determine if the wall outlet is live. Turn the machine on with the manual front switch and with the remote control. If the manual control works, but the remote does not, make sure the plastic shipping shield has been removed from the battery end of the remote. (Just pull on the little tab, if there is one.) Also check the remote battery if the remote controls don't work, but the manual ones do.
2) Make sure the little safety switch has the "I" end depressed and the "0" end out.
3) Unplug the machine, and check the fuse right beside the plug. Replace it with the EXACT same size, available from an auto parts store.
4) Carefully inspect the inside of the machine, looking for wires which are loose, corroded, broken, or missing. If you can't replace these yourself, find an electronics person who can do it for you.
5) Make sure the back screen is inserted firmly so that the internal safety switch is depressed. (You'll hear it click when the screen is in position.)
If none of these troubleshooting steps help, the problem is most likely in the computerized controls or motherboard, and that cannot be repaired. Vollara (EcoQuest's new name) is no longer manufacturing nor servicing the Breeze. However, if you call customer service (800-989-2299) they can give you some upgrade options. Your other solution is to try to find a dealer who has Breezes in stock and who might also have the spare computer components.
Feb 10, 2011 | Ecoquest Breeze AT Living Air Purifier
My Alpine Air 880 makes a sizzling noise. I turn the dial down and it gets better. Whats the problem?
The sizzling is the high voltage "bleeding" to ground inside of the collector module, or the high voltage electronic circuit.
First, unplug the unit and remove the module. Thoroughly clean all electrical contact points where the module makes connection. If it possible to operate the unit without the module in place, then replace all covers, plug the unit in, and attempt operation. If you continue to hear sizzling, then unplug the unit, remove covers, and continue to clean, digging deeper into the unit to find traces of accumulated dust/dirt. Also be on the lookout for burned areas in the plastic, around insulators, etc. High voltage is a mighty beast, and will easily track to ground, causing a sizzling noise.
If you don't find anything there, then take the modele and look for any tracking points on the insulators. Look very closely at the ionizer wires for accumulated lint, which creates little points where high voltage can bleed to ground from.
You may get popping of high voltage as well. When this happens, note the places where it occurs, and those places become suspect of causing the sizzling sounds.
Let me know what you find. These guys are cantanckerous at best.
Dec 14, 2009 | Alpine Air XL-15 Air Purifier
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
Sep 12, 2008 | Sharper Image Professional Plus Ionic...
How to find the carbon filter to change it and how we should clean the hepa filter on our
You should contact Honeywell to find out their parts rep for your area. I don't think you will find these parts in the regular hardware store.
Use Google to find the Honeywell home page, and work from there.
Jerry G.
Feb 18, 2008 | Air Purifiers
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Sep 06, 2007 | Filter Queen Defender Air Purifier
Hyundai 2011 - Accent Logo
55 people viewed this question
Top Hyundai Air Purifiers Experts
Tom Chichester
Bill Boyd
Are you a Hyundai Air Purifier Expert? Answer questions, earn points and help others
