Question about Gemini DJ CDJ-15 Player
How do i change a bulb, i think in my gemini cdj-15, cant see display?. Dave
Is it a bulb inside?
  • Mario
    Mario Dec 29, 2014
    Hi David Stubbins, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
CANT SKIP TRACKS AND THE SCREEN SHOWS A 100, I HAVE NEVER SEEN THE NUMBER 100 ON SCREEN, HELP!!!!!
I own one of these and its the same. Even more, functions works weird, it passes on usb while searching files on cd.... and more. Bad connections inside and firmware probably. Dont loose time and money to fix it. Doesn't worth.
May 25, 2016 | Gemini DJ Gemini CDJ-600
My midi cable is not detecting my laptop again because i reload it
IS IT USB - MIDI? TURN THE MIDI BACK ON IN YOUR SOUND CARD SETTINGS,& ON YOUR DEVICE.
Oct 25, 2013 | Gemini DJ Gemini CDJ-700
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
Dec 06, 2011 | Gemini Sound Products Gemini CDJ 203...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Gemini cdj600 not reading mp3, wmv format
WMV is a video format. You need to convert to MP3
Feb 24, 2011 | Gemini Sound Products Gemini CDJ 600...
My pitch slider has snaped off my cdj gemini 203's ? how do i fix it ?
The fader slider will have to be replaced. It is a bit of work, however finding the exact replacement often is hard unless you get it through the manufacturer.
Feb 04, 2011 | Gemini Sound Products Gemini CDJ203 CDJ203...
I have a Maytag Gemini range and the bottom oven is off by 25 degrees. When I set it for 350 it only gets up to 325 actual temp even though the digital display says 350. Is there an adjustment or do I have...
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
PROBLEM WITH MY GEMINI CDJ 02
just read about your issue with the gemini's 02, have had the same ones since december 06, and have had the same problems as you, mainly my 'play' buttons that broke down into the machine.
The first time I had it repaird by the shop I bought them at, after that had several times where the paly button broke into the machine. What I do now is to open the player by unscrewing the screws and it 'tape' the button where it should be.
The tricky thing is that when opening the player, there's like a sound card on top of the buttons, so you need to get that tape in between the card and the button, I learned to do this with a tweaser;
Having said that, I will also tell you that I've had it with this gemini hassle and that I will move to pioneer soon;
O.
Mar 05, 2008 | Gemini Audio Players & Recorders
Gemini DJ CDJ-15 Player Logo
145 people viewed this question
Top Gemini DJ Audio Players & Recorders Experts
chuck ringwood
chuck ringwood
James Kovacs
James Kovacs
T-Comtech Repairs
T-Comtech Repairs
Are you a Gemini DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
