Question about Triumph Academy Sports 400T Treadmill
My treadmill runs for 9 seconds and stops and shows E1
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Posted on Nov 24, 2014
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 05, 2010 | Startrac Fitness Products Star Trac 3900...
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Jun 07, 2009 | Exercise & Fitness
Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 20, 2009 | Exercise & Fitness
Triumph Academy Sports 400T Treadmill Logo
450 people viewed this question
Top Triumph Exercise & Fitness Experts
Mike
Mike
Electro Med Services...
Tom Chichester
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
