Question about Psi Air Tools & Compressors
Husky H1503tp compressor won't shut off when reaching 155 psi. The relief valve opens though. Just keeps running. How can I fix this myself???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Replace the regulator. the regulator tells the compressor motor when to start and stop.
Posted on Nov 26, 2014
SOURCE: air compressor 3 gallon
When I turn compressor on it does not build up any pressure ?
Posted on Oct 25, 2008
SOURCE: The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Posted on Apr 01, 2009
  • 7 Answers
SOURCE: I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Posted on May 02, 2009
  • 98 Answers
SOURCE: My craftsman 25 gal. 5 hp. compressor builds 120
Replace check valve the piston is getting stuck sometimes alloying the air to leak all the way down till it comes back on
Posted on Jul 21, 2009
ollie reece
  • 1167 Answers
SOURCE: when my compressor reaches 120 psi the safety
what is the working pressure bud
Posted on Sep 27, 2009
Husky 25 gallon compresor reaches 115 psi, not any more and keeps running, does not shut off
If it is not getting to pressure then either your safety valve is leaking or the drain plug on the bottom is open. Do you hear air escaping when it is running?
Nov 19, 2016 | Air Tools & Compressors
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
Motor does not shut off at 155 psi
The pressure shut off switch is not working right.. I would contact husky about a replacement part
Nov 28, 2013 | Husky H1503tp
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Compressor reaches 125 psi but does not shut down
Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
Compressor 25 psi thats it
I assume it keeps pumping, but doesn't build any more pressure. That is probably bad valves or rings. If your unit has a crankcase breather, and it is puffing alot of air, look for rings. Otherwise valves.
Dec 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Howdy, I just acquired an air compressor, ''Westinghouse Air Brake Co., Type Y 3YC, SN 136848. I am wondering about parts motor config, cfm output, psi, etc. It appears to be a 2 stage & I'm thinking...
We have a Westinghouse 3YC air compressor. The safety relief valve in the line between the two compressors started "popping off" recently. The compressor seems to be working fine. Is this a problem only with the relief valve or could there be a symptom of a more serious condition that we should be attending to? The valve is stamped 60 max which I assume is 60 psi. Is this the correct size. The tank pressure is set for125 psi. The tank relief valve is marked 250 max.
Sep 12, 2009 | Air Tools & Compressors
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
137 people viewed this question
Top Psi Air Tools & Compressors Experts
Don Numinen
Don Numinen
Richard Schanie ...
john h
Are you a Psi Air Tool and Compressor Expert? Answer questions, earn points and help others
