Question about Ld Okidata C3400n/C3530MFP/C3600n High YieYellow 43459301 Toner Cart
Where do you install the fuse for the transfer belt okidata C3530MFP?
I cant seem to find where the fuse goes for the reset on the transfer belt
  • 45 Answers
I hope you :changed the belt" rather than just reset it. Not a good thing to do. It will invite other problems such as Calibration/Saturation of toner-to-belt, and associated parts and boards.
Need more information,,,Steve
Posted on Dec 04, 2015
My OKidata c9500 makes a loud clicking sound when I try to print. Like a drum turning and maybe the contact is not
Similar problem in other Oki's
It's not a drum, I would check the ITB Belt. Known for binding failure.
Okidata didn't spend a whole lot of money/quality plastic/nylon bushings and parts associated with the drive roller and other associated part for their ITB Belt assembly.
I hope this helps,,,Steve
Oct 12, 2014 | Oki Electric Industry Okidata Corporation...
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Okidata 321 lxmc logic board blows fuse
We had a number of these. On the LXMC logic board is TR5. OEM is marked B882. It's a power transistor. Replacement is NTE264. Solves the problem and also solves some cases where space motor seems weak even though it is known good.
May 31, 2012 | OKI Office Equipment & Supplies
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
Okidata C3200N
It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
Jun 25, 2017 | OKI C3200n Led Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Ld Okidata C3400n/C3530MFP/C3600n High YieYellow 43459301 Toner Cart Logo
257 people viewed this question
Top Ld Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Ld Office Equipment and Supply Expert? Answer questions, earn points and help others
