Question about Pro-Team ProTeam Alpine CM DT100 HipStyle Vacuum Cleaner Now known as Tailvac
On the Pro Team Alpine how do I replace the receptacle?
There are rivets that need to come out. How do you remove them?
If the rivits need to come out You will need a drill and bit small enough but not too big and drill it out, u will need new rivits and a rivit gun u can find at local hardware store
Posted on Nov 26, 2014
No power on my pro team proforce 150xp
Generally a bad switch . We have the replacement fix.
Qualitymro.com
Dec 02, 2015 | Pro-Team ProForce 1500XP Commercial...
How do you start an electrolux floor pro
With the shampooer plugged in the receptacle and in an upright position with the handle up, step on the handle release with your left foot at the bottom left of the unit. It will release the handle back and also triggers the "on" switch at the same time. voila!
Hope it helps! amerivac4u@yahoo.com
Jun 07, 2014 | Electrolux Floor Pro Vacuum
Replace the mini emtor on a generation iv kirby upright
To replace a mini-emptor it should come of with a twisting motion. You may have to snap it if it is broken, and be aware in the exhaust port a piece may be left behind that you will have to remove to get the new mini-emptor to attach. There are 3 rivets that this part holds onto and when it is removed you should see the rubber and the 3 rivets. You can see pictures here: Kirby G4 miniemptor instructions.
GoodVac.com
www.goodvac.com
1-800-775-6586
Mar 19, 2014 | Kirby G4 Bagged Upright Vacuum
Vacuum will not come on even though power switch is on.
Rainbows draw a lot of power. It may have tripped the circuit breaker for the receptacle you have it plugged into. first make sure the receptacle is ok, especially if it is plugged into a ground fault receptacle. . Next, unplug the vacuum, take off the tank and see if you can spin the impeller by hand. If you can spin it, the motor is free. If plugged into a good receptacle and the power cord is not cut or broken and still does not run then the motor is bad. it could be the brushes in the motor(which can be replaced), or the armature is shorted out, meaning you need to replace the motor.
Jan 17, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Get no steam, light on so there is electricity, water in holder Pad correctly in place Model #S3101Q. Have tried plugging and unplugging. Filled the receptacle, changed pads. No steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101..
Oct 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a hoover F5914-900 steam vac clean surge how do you us ethe attachment for the hand tool thing?
on the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" . Now push the smaller water hose into the receptacle which is located under the hinged door on top of the base. It should be ready to go, now. let me know if this fixesya! Thanks, Rene (the Vacuun Doctor)
Nov 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I need to find out how to attach the hand tool to the machine. I have a spin vac spin scubber.
. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click". Then, on the top of the base there is a hinged receptacle that you plug the small hose into. You should be all set! Hope this fixesya! Thnks, Rene (vacuum Doctor) let me know if this helps!
Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Dec 30, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Replacing Switch & cord on OLD Eureka upright 403B or 403S (can't read)
http://geeksquad.fixya.com/support/t581907-replacing_switch_cord_old_eureka
Generic problem for all Vacuums
Replacing Switch & cord on OLD Eureka upright 403B...
Posted by volunteer2 on May 09, 2008
I have ordered and received what seems to be the correct switch and replaced the belt, but cannot figure out how to get to the switch. I also need to shorten or replace the cord because it is severely worn where it bends onto the winding posts. This old vac worked well until recently and is the property of our church and we can't afford to replace it right now.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a handle switch / cord and if you shorten the cord you need to also purchase a cord protector. Usually it may be covered by screws or a pop rivet and you would have to drill out the pop rivet and the switch cover will come off and then replace it with new pop rivets or screws and use the cord protector if you shorten the cord nut I would not advise it because the longer the cord the more vacuuming you can do without going from plug to plug. Suggest that you check with you local vac dealer in your area or use some suggestion I will give you listed below.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S. Customer Service Canada
Electrolux Home Care Products Electrolux Home Care Products
P.O. Box 3900 5855 Terry Fox Way
Peoria. IL 61612 Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 09, 2008 | Vacuums
Pro-Team ProTeam Alpine CM DT100 HipStyle Vacuum Cleaner Now known as Tailvac Logo
46 people viewed this question
Top Pro-Team Vacuums Experts
JoeVacs
Are you a Pro-Team Vacuum Expert? Answer questions, earn points and help others
