Question about Maytag Refrigerators
Water is pooling under the vegetable bins,..what possible causes can there be?
Removed back panel in freezer....no ice or blockage found.
Check the gasket, lower side of the fridge maybe deform or rusty. clean and reheat, with hot air or blower
Posted on Nov 24, 2014
4 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: We have a freezer top refrigerator...it's leaking
They normally have a drain hol at the back for condensation which can get blocked, if its more serious http://www.fridgeshop.net/ are very helpful.
Posted on Feb 27, 2010
Sea Breeze
  • 4655 Answers
SOURCE: water under vegetable bins and meat tray. ice build up which is leaking into freezer and water under frigerator
Defrost condensate drain line blockage is most likely what is happening here. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
You-Tube How to Fix a Refrigerator Leaking Water
Posted on Aug 06, 2012
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water on shelves
It sounds like the defrost drain is plugged. It is behind the back panel inside the freezer. Either defrost the whole unit, or use hot water to defrost the drain line. Be careful it is located right under coil and the fins are sharp! My knuckles have been cut many a time! Good Luck
Apr 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water running out from under vegetable and fruit
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Hook the other end , around the glass rod (defrost heater) carefully , to avoid breaking the glass , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 01, 2010 | Refrigerators
Sep 21, 2009 | Refrigerators
Water is pooling under the veggie bins- watere even came down via freezer door gasket to the floor. I have been noticing water in the right meat bin and in veggie bin, and under them for 2 weeks. most of...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 12, 2009 | Liebherr European Right Hinge Fully...
Water dripping into refrigerator from the freezer
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Jul 20, 2009 | Whirlpool Refrigerators
Kenmore refrigerator leaks water
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 25, 2009 | Refrigerators
Water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Jan 27, 2009 | Kenmore Refrigerators
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
52 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
